Samsung GTC3300 Cell Phone Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect in my pc by samsung pc stdio - Samsung GTC3300 Cell Phone
Anonymous
Level 3:
Guru:
  • Master 679 Answers
  • Posted on Jan 11, 2011
Anonymous
Master
Level 3:
Guru:
Answers
679
Questions
Helped
168756
Points
2165
Installation procedureFirst of all you need to have Samsung PC Studio installed on your computer. To download it, go to Samsung Download Center and choose the model name of your mobile.Installation using Samsung PC Studio:
  1. Connect phone to PC
  2. Run Samsung PC Studio if not running
  3. Open file manager (Click "Manage Files")
  4. Copy .jad and .jar to "Other Files" folder on phone. (You can download these files from our website)
  5. Disconnect phone and go to "Other Files", run .jad file to install and run the application.
If a message "Unsupported file format" appears, then it means that installing applications from PC is blocked in your mobile. In that case the simplest solution is to install per WAP. There are also ways to bypass this limitation and unblock the mobile. Try to search Google for eg. "C3300 Champ install jar" (witnout quotation marks) or "Samsung GT-C3300 Champ Unsupported file format"
1helpful
What meant by class library in c++
Libraries are used in the include command in the opening of a C programming string. They include standard and other libraries that are shortcuts so you don't have to write all that code. Ex: #include
<stdio.h> tells the compiler to go to the libraries if the path is set and to load the strings in stdio.h
Borland c++4.5 can not open sdio.h for windows7
stdio.h is a C header file
#include <iostream> //C++ for standard input output
or you can use
#include <cstdlib> // C standard library might work
I am develop one .net application and run to localhost i am get unable to connect visual stdio localhost...
Make sure that you have configured IIS properly. Many times even the asp.net gets corrupted and hence you'll be facing this issues.
1) Check whether IIS is configured or not. (Type "inetmgr" in the run and see whether the window comes or not)
2)UnRegister and then Re-register the asp.net
Unable to connect visual stdio localhost...
Check whether the IIS is first installed in the system or not, by typing "inetmgr" @ run, you need to get the IIS window open.
Then, unregister and re-register the asp.net with the iis.
In turbo c:unable to open stdio.h
first make sure you have the stdio file int the includes folder, and make sure that this is were the compiler id looking.
Then, in the begining of you code, write :
#include <stdio.h>
Programming c++ visual studio 2005 question?
pl. verify the main header do u hv mentioned eg. stdio.h for main i/p & o/p header.
Compilation error in Turbo c++ 3.0
#include <stdio.h>
The above line should be at or near the beginning of your program source file. If that doesn't work, you can try:
#include "stdio.h"
Of course make sure all the standard libraries and include
files have been installed. Otherwise you have a broken installation and virtually nothing will work.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
