Question about Seiko Pulsar watch
I own an older Pulsar Quartz Alarm Chronograph watch. It has a rotating dial that has time, alarm set, 0, timer, stop w. around it. The number on the back is 640409. How do I set the time?
Posted by mwss1974 on
Faisal Nazir
    Guru:
  • 113 Answers
Go on the following link download the instruction manual for watch and set the time of your watch
http://www.seikowatches.com/support/ib/index.html
Posted on Jan 11, 2011
Pulsar World Chronograph, World Timer
Click on the crown (the stem in the middle on the right side). There are three settings, and one of them will change the minute hands' behavior to normal. You might also check out this guide:
http://c01.coacdn.com/calibers/H800_condensed.pdf
May 07, 2014 | Pulsar Mens World Time Alarm Chronograph...
Can't set the digital time on Diesel DZ721
here are instructions from diesel:
http://store.dieseltimeframes.com/wcsstore/CommonDiesel/instructions/ENGLISH/Diesel_Digital-Guide_ENG.pdf
more specifically
TIME OF DAY MODE
1. Press C to toggle between Time 1 and Time 2.
2. Hold C for two seconds to set Time 1 or 2 as default.
3. Press D to turn on/off key tone.
Time 1
> To set Time, press A until hour flashes. Press B to select the setting
item. Use C and D buttons to adjust the values up or down. Press A to
exit set mode.
Time 2
item. Use C and D buttons to adjust the values up or down. Press A to exit set mode.
> The range difference between Time 1 and Time 2 is 23 hours.
CHRONO MODE
1. Press C to start and stop chronograph.
2. Press D to Split/Reset the chronograph.
3. Press A to recall the memory if Chronograph is stopped.
4. Press A again to view the next lap.
5. Press C or D to exit Recall mode and go back to Chronograph mode.
6. There are a total of 10 lap memories.
TIMER MODE
1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up.
2. Press C to start/stop the timer counting.
3. Press D to reset the counter to the preset value if timer is stopped.
4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute,
second and to back timer-type again.
6. Press C and D to increase/decrease the setting value.
7. Press A to exit the setting mode.
TIMER ALARM
Timer alarm will beep 2 times a second for 30 seconds.
ALARM MODE
1. Press C to select the alarm.
2. Press D to enable/disable the alarm.
3. Press B to change to Time mode again.
ALARM SETTING MODE
1. Press and hold A for 2 seconds to enter the alarm settings mode.
2. Press C and D to increase or decrease the settings value.
3. Press A to exit the settings mode.
Nov 19, 2012 | Watches
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    I have a seiko chonograph couturo alarm. 100m
    Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
    First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
    Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
    Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same ....er....time. You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
    Now you can set the alarm chime point.
    Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
    When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
    If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
    Jan 01, 2010 | Seiko Coutura Chronograph Watch
    I need instructions on setting the alarm for the Pulsar Chronograph 100M. I'm able to set everything else. Your response is greatly appreciated. THANKS!!
    I answered this for different Fossil watch post, but I believe it will be the same for your watch.
    I'll re-post the answer below.
    To set the alarm on these models of Pulsar watches, do the following:
    Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
    There are 3 positions on the crown: IN (#0), FIRST CLICK (#1) & SECOND CLICK (#2).
    The small dials located at the bottom of the watch face (6 O'clock) are the alarm minute and hour dials.
    First, pull the crown out to the second 'click' (position #2) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #2!)
    Second, set the correct time. (plus one or two minutes... time to complete this.)
    Third, with the crown still out to position #2, push button "B" (bottom) until the alarm minute and hour hands are set to the present time (same as the large dials).
    Fourth, push the crown all the way in- to position #0.
    The current time on the large dial should read the same as the small alarm 'time'. {This is the CURRENT TIME, not the alarm SOUND SET.}
    To set the alarm SOUND time, pull the crown out to the first click (position #1).
    Push button "B" until the dials of the alarm are at the time you want the alarm to sound... It can only be set within 12 hours! ... It does NOT know "am or pm".
    When the desired time is set for the "alarm sound", push the crown all the way in (position #0).
    The alarm dials will now indicate the time for your alarm to sound, NOT the current time. (this way, you know that the alarm is engaged.)
    To reset the alarm- or disable it, pull the crown out to the first click (position #1) and hold button "B" down until the dials advance and stop at the current time... it will stop at the current time- then release button "B". --- Push the crown back in (position #0) and the alarm will now be disabled.
    If the alarm dials are always moving and at the current time, you know that the alarm is disabled.
    If the alarm dials are stationary and not moving with the time, you know that the alarm is engaged and set to the time shown.
    I hope this helps.
    Nov 05, 2009 | Pulsar Chronograph Watch
    Can't set the alarm on a pulsar pf 3681
    Pull out the time stem to the first notch. Use the bottom button or reset button to change the alarm.
    Dec 22, 2008 | Pulsar 100 Meter Alarm Chronograph PF3277
    Sector 250 Chronograph Alarm
    the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
    pull the middle dial out to put it in alarm mode.
    To set alarm:
    -pull the center knob out.
    -with it out you can now use the bottom (right) knob to set the alarm.
    -pull the bottom right knob out one notch
    -turn the knob clockwise or counter clockwise to set the alarm time
    -push the knob back in (all the way)
    the alarm is now set
    if the center (right) knob is pulled out the alarm is ON
    if the center (right) knob is pushed in the alarm is OFF
    I have owned this watch for about 10 years now and love it.
    the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
    repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
    enjoy the watch!
    Dec 11, 2008 | Sector 2653940025 Wrist Watch
    Pulsar Gents Chronograph PF3501X1?
    OK YOU GO TO SET TIME BY PULLING OUT PIN TO SECOND CLICK OUT. THEN USE THE BOTTOM BUTTON TO SET THE ALARM DIAL TO THE SAME TIME AS THE MAIN WATCH HANDS. CLICK BACK IN ONE CLICK WINDER THEN USE THE BOTTOM BUTTON TO SET THE ALARM. CLICK WINDER BACK IN FULLY AND PRESTO YYOU HAVE IT.
    Feb 09, 2008 | Watches
    Seiko chronograph alarm
    Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
    Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
    Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
    Seiko Pulsar watch Logo
    667 people viewed this question
    Top Seiko Watches Experts
    Marvin
    Marvin
    Vernon Taylor
    Are you a Seiko Watch Expert? Answer questions, earn points and help others
