Heating & Cooling Logo
A
Anonymous Posted on Jan 11, 2011
I have a Haier split airconditioner HSU-22HD03, it runs for 5 minutes and then switches off and the power and timer light start flashing.
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Jan 11, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
952727
Points
6173
It shows your indoor PCB faulty. (As you didn't mention any error code). Next time count the green light flashing and write.Thanks.
I have haier split air condition Hsu 18ck03 When power supply off and comes back i manually switch on from remote.i want it auto on
Your air conditioner is not a inverter model(your model is it a low cost model )and doesn-t work automaticlly when the power is off
2helpful
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
1helpful
Looking for temperature sensor control for Haier Model DE45-RBG Numbers on part HSU-07 88A MC3A 94V-0
Here is the data sheet for the HSU-07.
http://www.maocc.com/pdf/hdk/e1321aa.pdf
There appears to be 5 different versions of the HSU-07 Let me know which one matches yours and I will try and find a source.
HSU stands for humidity sensing unit.
Keep me posted... on the actual part match per the pdf file.
Kelly
My airconditioner works for about 5 mins then stops and cant turn back on
First of all check your timer setting. Secondly, check your indoor coil sensor, may be weak, replace it.
Please clear one doubt that is your compressor working within that 5 minutes?
4helpful
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
