Question about Xerox WorkCentre M-24 Color Copier
Hie,am looking for a xerox M24 transfer belt at a cheaper price.Can you please help.Peter
Posted by peter_tavare on
Edwin Martens
  • 1,110 Answers
One of the best prices I have seen and they have the best aftermarket support for Xerox.
http://www.partsdrop.com/belt-64k91451-xerox-style-dc3535-p-1782.html
Good Luck with your Xerox and Thank You for using Fixya.
Posted on Jan 11, 2011
What is xerox m24 toners price ?
you'll find pricing here. other sources available, try a google search. Xerox WorkCentre M24 Toner
Mar 19, 2015 | Xerox Office Equipment & Supplies
Where is the transferr belt cleaner on a xerox workcentre m24
On the right side in the center of machine there is a small door you have to open that door and there will be the transfer belt there is also a handle to take it out you have to grab that handle and take it out slowly you will see the cleaning blade and assembly on the left side
Jan 23, 2013 | Xerox Workcentre M24 Color Copier
Need to replace transfer belt cleaner and 2nd bias transfer roll
Both are probably still good but the HFSI (High Frequency Service Item) counter needs to be reset. Unless something has changed with them that has to be done with the service laptop hooked to machine with a serial cable and using M24 diagnostics.
Jun 20, 2012 | Xerox WorkCentre M-24 Color Copier
How to replace the cleaning product of belt transfer (m24)? Thank you for your answer
1. Remove IBT Belt Assembly (REP 9.15).
2. Remove IBT Cleaner Assembly (REP 9.16).
3. Remove Stand Plate (Figure 1).
a. Remove screw (2).
b. Remove Stand Plate in direction of arrow. Stand Plate will be installed in new location
in step 7.
Jun 26, 2010 | Xerox WorkCentre M-24 Color Copier
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Our xerox m24 workcentre needs a new belt cleaner
Yeah, you do. Sadly that is only on a Xerox rep laptop.
The diagnostics in that machine are not in the processor but accessed via laptop.
Instead of calling Xerox, you can look up a dealer in your area. They would do it and if you have no maintenance agreement they will do it for much much cheaper, what city to you live in? Let me know and I will send you the names of dealers in your area.
E-mail me at [email protected] dont want you putting your city name on here. I will look them up and send you the info on dealer service in your area.
Feb 12, 2009 | Xerox WorkCentre M-24 Color Copier
Xerox WorkCentre M-24 Color Copier Logo
207 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
