Question about Altusen Aten CS64U--4 Port USB KVM Switch(CS-64U) compatible with pc/Mac/Sun/Linux
I have Aten USB KVM Switch, and i lost the user guide. I need to switch between the Pc's, what is that hot key i have to press to switch it. M.J Regards
Posted by M Jamil on
Anonymous
    Problem Solver:
  • 14 Answers
You can check out here- there's a lot many Aten usb kvm switch, check your model and find out how to resolve your problem http://www.kvmstuff.com/server-management/kvm-switches/usb-kvm-switch.html
Posted on Jan 11, 2011
Can't switch
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, try tapping scroll-lock twice to switch. It's much better than trying to use the num-lock + and - keys, since it's only a two-way KVM. Tapping Num-lock twice automatically switches, so you don't have to hit multiple buttons.
Oct 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Lost the instructions for the CS62U switch
here is the link to the aten website.
go to the select quick guide section and locate the model # in there,
p.s. its cs not c5
Aug 15, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Lost the hotkeys,Cant switch.
Found this:
http://safemanuals.com/user-guide-instructions-owner-manual/BELKIN/F1DL102P-_E
Hope it helps.
Let us know
Good Luck
Apr 13, 2009 | Belkin F1DL102P 2-port KVM Switch
KVM Switch 4110 8 port
so is the KVM (control side, PS2 mouse / kbd>??)
or are all PS2 ports wired to adaptors,? i cant guess this nor what was used before, no history stated.
what was there before, this act?
and what now?
Ill assume worse cases (tossed a coin)
18 (16+2) adapters now. all devices are USB but KVM
ok.?
what mode fails, both the KVM pushbotton switch and or the hot key commands on the kbd?
Oops no manual button as seen on modern KVM.
KVMs are very complex. the hard part is the vast number of different PC.
USB , PS2, VGA, DVI and HDMI.. yah,..
OK 16 +2=18 x ps2, and 9 VGA ports. it is.
NO KVM does it all, ,, old KVM' do NOT work , on new computers, all folks know this , if they tried. or took readings to learn why it fails.
I bet power to the KVM is dead., no LED./
no manual button ,oops.
pin 4 PS2 reads 5vdc and connected up, same?
we use breakout boxes (DIY) to test ports connected.'
that Compaq is very old and no support now, no books.
why not ask at real HP, maybe some old guy there can dig it lost books>
40 KVM? that what you said, really? (or 40/8=5 kvm)?
my guess is the adaptor does not work or power issues
KVM >>PS2>>>ADapt>>> USB.(server) (usb 1,2,or 3 at server?)
The KVM in most cases, here, steals power from PS2 ports but not this KVM , its better.
i'd bet that adaptor cant do that.
(is the caps lock key working on the KBD and laser LED glowing on said mouse?
ask here, real HP.
lets see tests:
1: pin 4 ps2 5vdc?
2: mouse glows?
3: keyboard led , caps lock toggles? (glows)
4: lost the hot key commands (y/n)
one other problem is the BIOS in the server may not like your adaptor at all. When BIOS scans the keyboard. it expects a ID response if missing or grabled, it drops that device port.
https://h30434.www3.hp.com/
btw, one way to cure this, is run headless server software
end KVM for ever.
i run a LAMP server, that comes in the box, no kvm no any thing on ports. it has a web page to go to and do service that way.
port IP+:12321
modern ways work best.
in a server farm, a keyboard/mouse/monitor on rolling cart
for the super sick servers is best...
the other problem is USB only PC or server
does not scan PS2 ports, it has none
so if the adaption fails, at boot time, all is lost.
(BIOS reports connected devices to the OS)(unstated by you)so if the report fails, problems happen
for sure after the boot.
this device is s business device, now ("Enterprise)
the posts on it are like 10 years ago. all links to books now dead.
infact the compaq server that had them is turned off. (grin)
here is my search there. Why not ask them?
https://www.hpe.com/us/en/search-results.html?client=&qt=kvm+4110&search=%EF%98%90&cc=us&charset=utf-8&hpa=http%3A%2F%2Fwww8.hp.com%2Fus%2Fen%2Fhpe%2Fcontact%2Fcontact.html&hpn=Home&hpr=http%3A%2F%2Fh41131.www4.hp.com%2Fus%2Fen&hps=Home&lang=en&qp=url%3Ah41131.www4.hp.com%2Fus%2Fen+url%3ANEW+URL+GOES+HERE
Aug 26, 2017 | Compaq 242695-001 8-port KVM Switch
Tripp Lite B034-002-R 2-port
press numlock twice. There may be other hotkeys, but that's the one that I use. Occasionally mine gets confused (because of reboots and hibernation) and I need to unplug the usb cables from each PC and then plug them back in. Then it works again.
Jun 25, 2008 | Tripp Lite B034-002-R 2-port KVM Switch
Computers & Internet Logo
Top Altusen Computers & Internet Experts
k24674
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
