Russell Hobbs 10617 Glass 2-Slice Toaster Logo
Posted on Jan 11, 2011
The Stop function is allways on and Therefore i must press down the barr.
A
Anonymous
Click on the link below to read the solution to this problem:
http://www.fixya.com/support/t1187710-lever_not_stay_down
2answers
Mechanic put bars stop leak in my 1999 grand am se and it is running hot and wany hold coolant
Gm used the Barrs stop leak right from the factory to seal up new blocks. It was the kind made from walnut shells not the metal sealant. He may have used too much if you are overheating. I would do a good flush and go get the bars stop leak in the tablet form, follow directions and see if that helps. I had a persistent leak from my lower intake manifold, already replaced it once, put some Barrs in and now have zero leakage, no overheating either. I would have re-replaced the manifold's gasket but the car is just a beater. Now this stuff is a bandaid not a repair. So if you push the car hard the leak will reemerge.
I have a Grundig radio S350DL and I cannot switch off the sleep function and therefore the radio automatically switches off after 30 mins. or so . Can you advise? Les. Akers
The Power and Sleep Functions share the same button. If you press the Power/Sleep button repeatedly you see numbers displayed 90, 75 60, ... 01. These are the duration of the sleep functions. If you stop at 60 the radio will work for 60 minutes then turns itself off. This must be a battery saving feature so that a radio will not be on for ever. Suppose the radio has been on for a while (long or short) and you want to turn it off without waiting for the sleep timer. Just press the Power/Sleep button.
1helpful
3answers
I want o update my nokia n70 but where....?
Imagine ur cell battery is very low, u r expecting an important call and u don't have a charger.
Nokia instrument comes with a reserve battery. To activate, key is "*3370#"
Ur cell will restart with this reserve and ur instrument will show a 50% incerase in battery.
This reserve will get charged when u charge ur cell next time.
*3370# Activate Enhanced Full Rate Codec (EFR)-Your phone uses the best sound quality but talk time is reduced by approx. 5%
#3370# Deactivate Enhanced Full Rate Codec( EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound
but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
2 *#0000# Displays your phones software version,
1st Line :S oftware Version,
2nd Line : Software Release Date,
3rd Line : Compression Type
3 *#9999# Phones software v ersion if *#0000# does not work
4 *#06# For checking the International Mobile Equipment Identity (IMEI Number)
5 #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
6 #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
7 #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
8 #pw+1234567890+4# SIM Card Lock Status.(use the "*" button to obtain the "p,w" and "+" symbols)
9 *#147# (vodafone) this lets you know who called you last *#1471# Last call (Only vodofone)
10 *#21# Allows you to check the number that "All Calls" are diverted To
11 *#2640# Displays security code in use
12 *#30# Lets you see the private number
13 *#43# Allows you to check the "Call Waiting" status of your phone.
14 *#61# Allows you to check the number that "On No Reply" calls are diverted to
15 *#62# Allows you to check the number that "Divert If Unrea chable(no service)" calls are diverted to
16 *#67# Allows you to check the number that "On Busy Calls" are diverted to
17 *#67705646#R emoves operator logo on 3310 & 3330
18 *#73# Reset phone timers and game scores
19 *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it
means you will get the best standby time possible
20 *#7760# Manufactures code
21 *#7780# Restore factory settings
22 *#8110# Software version for the nokia 8110
23 *#92702689# (to rember *#WAR0ANTY#)
Displays -
1.Serial Number,
2.Date Made
3.Purchase Date,
4.Date of last repair (0000 for no repairs),
5.Transfer User Data.
To exit this mode -you need to switch your phone off then on again
24 *#94870345123456789# Deactivate the PWM-Mem
25 **21*number# Turn on "All Calls" diverting to the phone number entered
26 **61*number# Turn on "No Reply" diverting to the phone number entered
27 **67*number# Turn on "On Busy" diverting to the phone number entered
Each command is prefixed with either one or two * or # characters as follows:
** Register and Activate
* Activate
## De-Register (and Deactivate)
# Deactivate
*# Check Status
© Call button
Once each command has been entered, if it is a network command (as opposed to a local handset command) it must be transmitted to the network by pressing the YES (receiver) key which acts as an enter key - this is represented here with the © character. Always enter numbers in full international format +CountryAreaNumber ( e.g. +447712345678).
Command Description Command String
Security
Change call barring code **03*OldCode*NewCode*NewCode#©
Change call barring code **03*330*OldCode*NewCode*NewCode#©
Change PIN code **04*OldPIN*NewPIN*NewPIN#©
Change PIN2 code **042*OldPIN2*NewPIN2*NewPIN2#©
Unlock PIN code (when PIN is entered wrong 3 times) **05*PUK*NewPIN*NewPIN#©
Unlock PIN2 code (when PIN2 is entered wrong 3 times) **052*PUK2*NewPIN2*NewPIN2#©
Display IMEI *#06#
Call Forwarding (Diversions)
De-register all call diversions ##002#©
Set all configured call diversions to number and activate **004*number#©
De-register all configured call diversions (no answer, not reachable, busy) ##004#©
Unconditionally divert all calls to number and activate **21*number#©
Activate unconditionally divert all calls *21#©
De-register unconditionally divert all calls ##21#©
Deactivate unconditionally divert all calls #21#©
Check status of unconditionally divert all calls *#21#©
Divert on no answer to number and activate **61*number#©
Activate divert on no answer *61#©
De-register divert on no answer ##61#©
Deactivate divert on no answer #61#©
Check status of divert on no answer *#61#©
Divert on not reachable to number and activate **62*number#©
Activate divert on not reachable *62#©
De-register divert on not reachable ##62#©
Deactivate divert on not reachable #62#©
Check status of divert on not reachable *#62#©
Divert on busy to number and activate /td> **67*number#©<
Activate divert on busy *67#©
De-register divert on busy ##67#©
Deactivate divert on busy #67#©
Check status of divert on busy *#67#©
Change number of seconds of ringing for the given service before diverting a call (such as on no answer). Seconds must be a value from 5 to 30. De-registering the same divert will also delete this change! **service*number**seconds#© (Service numbers, see below)
Call barring
Activate barr all outgoing calls (see Security to set code) **33*code#©
Deactivate barr all outgoing calls #33*code#©
Check status of barr all outgoing calls *#33#©
Activate barr all calls **330*code#©
Deactivate barr all calls #330*code#©
Check status of barr all calls /td> *#330*code#©<
Activate barr all outgoing international calls **331*code#©
Deactivate barr all outgoing international calls #331*code#©
Check status of barr all outgoing international calls *#331#©
Activate barr all outgoing international calls except to home country **332*code#©
Deactivate barr all outgoing international calls except to home country #332*code#©
Check status of barr all outgoing international calls except to home country *#332#©
Activate barr all outgoing calls **333*code#©
Deactivate barr all outgoing calls #333*code#©
Check status of barr all outgoing calls *#333#©
Activate barr all incoming calls **35*code#©
Deactivate barr all incoming calls #35*code#©
Check status of barr all incoming calls *#35#©
Activate barr all incoming calls when roaming **351*code#©
Deactivate barr all incoming calls when roaming #351*code#©
Check status of barr all incoming calls when roaming *#351#©
Activate barr all incoming calls **353*code#©
1helpful
How do I scan to my computer using the Cannon Imageclass MF4370 without getting up each time and pressing the scan button on the printer?
Sorry, you must get up each time and press scan button!
...or you can tell the copier under user mode - machine sett. - that you want scan as first function. That the machine will allways on scaner function. But when you want to copy or fax you will need to get up and transfer to wanted function, but scaner will be allways on :-)
Stop a person pestering me.Barr their number?
Set your phone to closed user group, in that way only the ones that you specify there can call you. Hope it helps.
1helpful
Cooling issue
I've always had good luck w/MASTER SILVER STOPLEAK by master corp. memphis tenn, silver flakes,use like barrs.yes,the system is pressurized,and pressure can increase slightly when you shut it off.
I purchased a phone but its blocked, the phone not the sim how can i unblock it
If it is blocked it means that it has been barrred by the networks due to being reported lost/stolen and therefore it can not be unblocked,so can not be used to make or receive calls allow some of the other functions may still work on it,camera etc
If it 'locked' rather than 'blocked' that is entirely a different matter and it can be unlocked
2helpful
Model SMPV 4GBTA. I have no instructions on how
To unlock the screen, press and hold the menue button for a least 5 seconds
Adjust the volume by using the vertical slide barr, up or down
Keyboard
Do you have a function key on your keyboard as this may have been pressed and therefore accessing shortcuts on your keyboard. The function key normally looks like this
Fn
Not sure but this may be your issue. Some function keys need to be held down and others will go on when pressed and stay on until they are pressed again.
Let me know if this helped
Cheers
John
2answers
VW Passsat - 98 -
ABS and coolant are unrelated unless there is a problem with the ECM (engine control module) or instrument panel. Is the red coolant warning sign for coolant level or temperature?
With ABS if there is any failure with any brake electronic component (sensor, motor, or fluid level etc) the ABS will shut down completely and flash the light. If the light is on or flashing the ABS is non functioning.
I need better information on the coolant and ABS to give better information.
Top Russell Hobbs Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Usman khan
Usman khan
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
