Unlock forgotten password with tool from http://www.windowspasswordsrecovery.com/
There are two tips for you to reset windows password .
1. Enter into safe mode, log in as default admin account, there is no password in it. If the default account password has been changed, see next
2. Find Windows Password Reset and download it from http://www.windowspasswordreset.net ( You can do in any computer not yours). Burn to a blank CD or USB, Insert it to your computer then use the disk to reset your password to blank without knowing the current password.
Try to log into SafeMode using built-in administrator account (hope you did not password protectit,), then reset your other password in safe mode as follows: 1. Click Start button, and select Run 2. Type "control userpasswords2" 3. Select account you want to reset passwordfor and Change password on it If failed, takeadvantage of Windows Password Recovery to create a password reset disk withCD/DVD or USB flash drive. 1. Get Windows Password Recovery from http://www.anypasswordrecovery.com/ 2. Burn a password reset disk with CD/DVD orUSB drive and the program 3. BIOS settings 4. Reset lost password with the burnedpassword reset disk.
If you forget password of windows do these works:
1-
restart your pc
2- before loading windows Press F8.
3- select
safe mode.
4- in user selecting screen, select administrator.
5-
log in freely and do any change you want.
but if you forget password of bios do these:
1- intercept all of cables from your laptop.
2- open back lid and evolve the battery.
3- wait 15 minutes.
4- put the battery and turn on the laptop.
If you have another account on your laptop that has administrator rights, log in into that account and change the password for your account. If you have an administrator account (even if you don't, try putting in Administrator and leave password field blank) try using that account to reset the password, otherwise try one of the following:
- see this for XP http://support.microsoft.com/kb/321305
- or this for Vista/Win7 http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
- or if anything else didn't work you can use third party software from Hiren's Boot CD to reset your login password http://www.hirensbootcd.org/download/Hirens.BootCD.12.0.zip
A Windows password reset bootable disk could do all the job for you, it can reset your lost or forgotten Windows password safely and quickly without login, you can create a Windows password reset bootable disk with the tool Windows Password Breaker, then use it to reset your password.
