This is one of three issues. First when it is on do you hear a Click sound from the back of the unit and another click within a few seconds. If you hear this and no loud humming sound it is should be the start device. Another way to check for this is to unplug the unit and take off the bottom back panel (usually 1/4 in driver screws for cross tip). Once that is off you will see wires going to the side of the compressor into a little box(start device) on the compressor. Look for any signs of blacking(burnt marks). If you remove the metal clip holding the start device it should pull off. If it sounds like a baby's rattle when you shake it, its toast.
Part Number: 218721119
If these checks seem to be ok it is most likely a seal system issue and must be fixed by a Federally approved Technician.
If the Compressor is not making any noise and is cold to the touch then it could be a Defrost Control (240554502) or Refrigerator side Temp Control(5304482075)
there is a evaporator defrosting problem; ice building-up. the evap fan is mounted right on top of the evap coil. this will get progressively worse; and, the fan will get completely jammed with ice; and stop altogether. your fridge will get warm and the freezer will not cool properly. you should get it looked at asap..
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
