Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
Posted by organizor on
jack ridic
    New Friend:
  • 3 Answers
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Posted on Jan 23, 2011
  • BillChia Mar 07, 2011
    Not sure, just yet, if it works, but at least the problem description seems to be spot on.
Small condencer on my 39P400 has two coloured wires red &blue which wire goes onto what pole ??
Either way around it doesn't matter. Unless it is marked with a P & N or + & - then red would go to P or +
Jun 15, 2017 | Simpson Washing Machines
My Simpson eziloader front loader 5.5kg will not fill up with water
get the water inlet valve replaced or clean the water screens in the hoses ,possibly
Aug 28, 2016 | Simpson Washing Machines
My Simpson eziload 750 will not shut off the water during cycles when supposed to
Start machine as normal. After a few seconds of filling, press the pause button. Water coming in should stop immediately. If it hesitates then stops or does not stop at all you have a faulty inlet valve. Change it.
Apr 22, 2016 | Simpson Washing Machines
My simpson eziloader machine won't start - when I press the start button it clunks a couple of times then nothing - water won't enter have checked the inlet pipes
sounds like blocked pump or door latch sensor/switch more likely pump blocked.thats normally first to activate in wash cycle.if unsure seek help to locate and check.it ll be either accessable from bottom front of machine or you may need to tip it up as it ll be at bottom of machine.unplug first,and if you pull pipes off pump to access there will be some water.hold waste pipe as low as itll go to release any water left in machine
Feb 21, 2015 | Simpson Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson eziloader 5.5kg. I turn it on it fills then slowly spins to the right, pauses and then slowly spins left the same time then repeats this sequence. Is it the timer mechanism. If I put on extra...
You can try to reset the program by pulling out the plug and then put something (iron like a screwdriver) between the 2 pins of the plug.this wil cause the voltage that remains in the circuit to short connect and will so reset the memory in the program.
Sep 25, 2017 | Electrolux Washing Machines
I would please like a manual for the simpson eziloader front loader washing machine
45s558e_lr.jpg A 5.5kg capacity front load washer with a stainless steel spinbowl, 8 wash programs, variable spin speeds, 2.5 star energy rating and a WELS 4 star water efficiency rating (56 litres). General Specifications Colour: white Overall Dimensions (Check installation guides in downloads for exact dimensions) Overall Height: 850 mm Overall Width: 600 mm Overall Depth: 630 mm Key Specifications and Features Capacity: 5.5 kg Energy star rating on old scale: 2.5 stars Spin Bowl: Stainless steel Wash Programs: 8 Water efficiency star rating (WELS): 4 WELS Water consumption: 56 Litres Other Specifications Door opening - Large: 300 mm Door opening angle: 165 degrees EAN: 8853328005026 Variable spin speeds: 800,650,500 rpm Other Features Colours 40/ Colours cold: Yes Cotton 60 / Cotton 60 eco / Cotton cold: Yes Cycle start/pause button: Yes Delicates 30 / Delicates cold: Yes Extra rinse: Yes EZILoader: Large EZILoader doors makes loading and unloading your washing easy. Levelling legs: The levelling legs may be adjusted if the floor is not level, to ensure correct operation of the washing machine Pre-wash: Yes Pushbutton electronic options: Yes Quick Wash: Yes Rinse/ Drain / Spin: Yes Rotary Electronic Controls: Yes Wool 30: Yes Warranty Details 2 years from the date of first purchase (3 months for commercial applications) and subject to the conditions set out in the warranty card accompanying the product when purchased.
Aug 06, 2011 | Washing Machines
How do I get the top cover off a Simpson Eziloader washing machine model 45S708E ?
Most top loading machines have a couple of screws at the back and sllide backsward and the lift off. I cannot find a diagram online to confirm this but it's worth a try
Jul 08, 2010 | Washing Machines
Simpson Front Loader won't start - Clicking Noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 03, 2009 | Washing Machines
Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Washing Machines Logo
509 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
