its in the freezer near the top if its not cooling I would check ur air damper flow control, is it to far close or opened? check the cold control thermostat, the thermistors. and of course the fan itself, check door seals.
I would say you have a bad jazz board,do this open the right hand side door of the fridge,you'll see on the touch pad the up and down arrows,hold the light switch in and press the down key three times,let go of the light switch press the down button again and i think it says like s and p can't remember but press the down one more time and you should see 4 and 4 or whatever settings you had if you see this close the door,open the freezer, by doing what i told you you manually put it into defrost,if you hear the compressor running the board is bad part WPW10503278 and i have to tell you i've changed quite a few of these boards.also if the strip between the doors are hot check you coil on the bottom,usually when this happens the condenser coil is blocked with dust or the condenser fan isn't blowing,if you ever find the fan not blowing you can get a house fan and blow it onto the compressor and coil this will keep it cool until you change out the fan motor and you won't loose any food but that's another day.your coil might just need to be cleaned or the jazz board could be causing this because the compressor is running longer than it should.if you unplug the fridge,melt out all the ice off of the coil as best you can but the more the better you'll be able to use the fridge like normal for like 10 to 12 days then the coil will freeze up again so order the board melt out the ice with a hair dryer and you should be fine,if you need a hand programming the new board let me know i would tell you how to do it but i don't know if people are getting my answers nobody writes back,so open the freezer door,open the right side door,hold the light switch in,push the down button three times,let go of the light switch and push the down pad again and one more time you should see settings again,close the door,if compressor is running the board is bad.
https://www.youtube.com/watch?v=HUoGLZYv...
one more thing if you remove the bottom kick plate there should be a tech sheet either folded up and it's in the kick plate or it's in a plastic pouch taped up to the floor check right side but could be on left too and clean the coil while you're down there
if you are worried that the freezer is empty....fill it with plastic bottles of water...remember tho,don't fill the bottles completely as frozen water expands.
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp. The problem could be the electronic control if
you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
