Question about Malber P21 Front Load Washer
Broken front door handler,I need door or broken part-opener
Posted by izijadic on
Appliance Guru Gold Coast QLD 4213
    Master:
  • 330 Answers
Its called a screw driver and force what your looking for.then you have to replace wat ever broke.
Posted on Jan 11, 2011
Heat defrost
blend air door in your air handler is not working. bad servo or broken door.remove glove box and you should be able to view the servo on top of unit switching controls see if it operates if it does the door hinge is broken and air handler has to be removed to repair.this is a all day job even for a pro,dash(cowl) has to be removed
Dec 09, 2013 | 1998-1999 Dodge Ram 1500 Truck 4WD Front...
Windows on passenger side front and rear won't work, up or down.
He could have been more helpful and explained it's likely some broken wires in the door openings. Check carefully the wire harness in the front driver's door and in the passenger front door, where wires get stressed the most when opening and closing doors. The driver's window switch is the master switch for all windows, check there and the other doors openings for broken wires. Splice back together any broken wires you find and recheck windows. Hope you find it. If not there, but somewhere else in the harness, you would probably need professional help to find it.
Feb 15, 2013 | 2004 Mitsubishi Endeavor
A c not blowing in the front of the car
the air diverting system at the evaporator under the dash is not working. they are vacuun or electrical and needs to be freed up or replaced. if electrical check your fuse box to make sure that it didnt blow a fuse. if vacuun operated make sure the line didnt come off that supplies it. if you can get to the air handler door make sure it works freely to open and close.
Jun 04, 2010 | 2005 Dodge Caravan
Cannot open the front door on an Electrolux ECO 7 kg front load washing machine. Feels as trhough the door clip has broken
I really did not fix the problem. I think the plastic linkage may have been broken and I was looking for a fixto open the door.
Thanks anyway,
Jim Charlesworth
Jan 10, 2010 | Electrolux EW1200i Front Load Washer /...
Kenmore 106.55526400 door handle needs mounting
Yes the door will need to be partially disassembled to reach the back of the screws. The handle is the lowest price I could find is at Sears Parts Direct CLICK HERE=> http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
Get an account and enter model number.
To see the photo of the door click here below
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0404023-00006.png
If you need more help please let me know. [email protected]
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Trying to help but, Not sure you will be interested in the repair, Thanks, Sea Breeze
Aug 15, 2009 | Whirlpool ED2FHEXN Side by Side...
I only get warm air blowing out of the front vents
sounds like the air handler for the front is inoperative the wheel that operates it may be broken. its in the dash.
Jul 05, 2009 | 2004 Lincoln Aviator
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Outside door handler broken and child lock is on how do i open
Acura's and honda door handles are a little tricky to do.
make sure the window is all the way up.Then
1. u must remove the inside door panel.
next there is a plug on the inside edge of the door . remove this plug.
2. there is a 10mm bolt that hold the door handle on.
on some honda's and acura's door there will be a latch connecting rod. you will need a small tipped screw driver to remove this.
3. next there will be a 10mm bolt connecting the handle to the door inside. remove this bolt.
once the bolts carefully lift the handle upwards to remove the handle from the outside of the door.
At this point u can remove the door latch and other items that u wish to replace.
To install.. reverse this procedure.
Note.. is some cases there will be connecting wires to the handle and door latch itself. they must be disconnected prior to removeing and other components. Its a pain to do, but if u do not do this the connections could break and it is even harder to repair.
Take your time and don't force the parts apart. they are only plastic
Apr 17, 2009 | Acura TL Cars & Trucks
Door handle will not engage with latch to open door.
yea but the trick is the latch acces is behind console not the front panel, you need to unistall the d/w slightly to remove strike plate holding broken latch closed, door needs to be opened to gain access to console screws
Feb 22, 2008 | Dishwashers
Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Jan 29, 2008 | Washing Machines
Malber P21 Front Load Washer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
