Scientific Toys North Pole Express Xmas Train set Logo
Posted on Jan 11, 2011
How do you get it to smoke? What do you put in it?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
6920
Points
9
Why is smoke coming from the back then i have changed the oile but not the fiter n i got a new pcv put on in put smoke trement n my oil plz tell me wats wrong
black smoke is gas is running to rich,,, blue or gray smoke is oil burning.. did you overfill your oil ? if you didn't change the filter you may have too much oil in now..
I put a 91 roadmaster in a chevy truck and now it smokes real bad then it clears up i put a map sensor on it already what else could it be?
since you've replaced the map sensor I'll assume you're dealing with black smoke. a bad coolant and/or intake air temperature sensor could create black smoke, also a bad injector could do it, especially if it's monopoint injection.
1998 xr80 smoking after puting freash gas in
Did you put in 2-cycle mixed gas? If putting gas in it was the last thing you did before it started smoking then I would start there. Oil causes smoke and there's only 2 ways oil can get into the cylinder; mixed with gas or bypassing the piston rings. Lets hope its the gas.
2answers
I have a honda accord 97 v tec T fix the head and put the main bearing and stil smoked
white smoke is water lite blue or black smoke is oil. Replacing the main bearing would not cause it to smoke, Could be eather a bad plug not getting fire or oil fillen, or bad ring's good luck to you.
2answers
Last week my 1984 nissan truck started smoking. It clears up and started smoking again the next day. That same day I put in brake fluid and power steering fluid before it started smoking. My brother in...
It's possible you overfilled the power steering reservoir or perhaps spilled some that leaked down on the exhaust manifold. That would cause a lot of smoke until it burned off.
1helpful
Put some oil in Toro Z400 mower, engine smokes a lot (white
yes sounds like it, take your sparkplug out and clean or replace it and crank engine over a few times to blow out any oil in the cylinder
May 19, 2010 • Garden
White smoke useing a little oil
sound like your valve seals are goin. I wouldn't worry about it until it starts smoking alot more and burning alot of oil.
Top Scientific Toys Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Scientific Toys Toy Expert? Answer questions, earn points and help others
