Question about Panasonic GigaRange KX-TG5240M Cordless Phone
When the Talk button is depressed on one of our two handsets the screen reads: "No link to base. Move closer to base and try again." The other handsets performs as it always has.
  • Anonymous Jan 11, 2011
    The recomendations I received were not useful - 1 did not work and the other was to replace the system. I am sending the phoine out to be repaired instead.
    Please credit ny card back the $10.
    Jim Monroe
    This solution was simply explaining to me how the refund process works in regards to the feedback process.
Ginko
  • Panasonic Master
  • 19,396 Answers
Hi Jim.
About the problem with the answer received, you should write to [email protected] They usually reply within next working day.
About the system, if you have not sent the system for repair yet, you should do a full system power reset. This is done performing the following, simply disconnecting the power adapter won't be enough:
  • Disconnect all power adapter cables from wallsockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units in the system is defective.
I wanted to remind that the feedback given to the expert does not afftect refund procedure, and do not affect your status. In some case I get negative feedback while trying to help dissatisfied
askers in troubles with Fixya service. That is not really nice and pleasant. :)
All the best.
Ginko.
Posted on Jan 11, 2011
  • Byron Narciso Jan 12, 2011
    I cant say anything the device really needs to be service .We've done our part as an expert . :)
Byron Narciso
    Guru:
  • 679 Answers
Unplug the power and phone cords from the wall outlet and let it sit for 30 minutes or more "the longer the better" This may reset the processor ic back into normal operation, if it fails! the only solution is replace your phone system, because the repair to your phone would not be cost effective.
Posted on Jan 10, 2011
The telephone batteries are fully charged; however when I attempt to use the telephone I receive a message stating, "No link to base. Move closer to base, try again." The telephone is very close...
Check your user's manual for registration, or RE-REGISTER the handset to the base. In essence, it involves stepping to the registration on the handset, pushing the handset locator button on the base, then saying OK on the handset. They will sync up.
Carl
Feb 10, 2011 | Panasonic Lands Phones
I have Panasonic KX-TG6051M cordless phone. I have been using it for years with no problems. I now get the message:"No link to base. Move closer to base, try again." I have read the user manual...
Hello! Have you re-registered the handsets? If not go to page 39...If you have re-registered the handsets...Pull the batteries for 1 hour...reinstall batteries...allow handsets to set in the cradle for 1 minute then test...
Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 01, 2011 | Panasonic KX-TG6051M Cordless Phone
No link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
Feb 23, 2010 | Lands Phones
Handset is fully charged and states No Link to base. Move closer to base, try again. This does not work as it has been tried.
before using the phone,the handset has to be registered with the base...from the menu select handset registration..then press the speaker button for some time which will register the handset...if u have a manual for this phone,please try from that book about handset registration..
Oct 22, 2009 | Panasonic KX-TGA101S Cordless Handset
No link to base.
unplug the base and when you plug it back in
the handset should work
Dec 13, 2008 | Panasonic KX-TG2356 Cordless Phone
PANASONIC KX-TG2431 CORDLESS PHONE
The handset is away from the range of the base. Keep the handset on the base for some time and then try again.
Aug 25, 2008 | Panasonic Hybrid IP 12 Key Add-in Mod use...
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
No Link to base. Move closer to base and try again.
Re-Register!
That's right.
Wait, don't look for any product registration card you think you still have. You probably threw that away with the packaging the first day you opened it.
On the Handset:
Know which handset you have (#1 or #2)
Menu --> Initial Setting --> Registration
The Handset will say follow the instruction on the manual which you don't have.
Now, go to the base unit:
Press and Hold the Handset # button (#1 or #2), until you see the display on the base unit changes.
You can release the # button now.
Press <select> button on the handset.
Wait until you hear beep.
You're done!
Apr 04, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
No link to base move closer to base
Your getting this message because the radio portion of the handset or/and base is not communicating with each other. This can be temporary or fatal. You can try re-registering the handset(s) to the base by following the directions in the manual, its fairly easy to do for any model. If that does not work,and you have more than one handset not working with this problem, then it sounds as if your base needs repair or replacing.
Feb 04, 2008 | Panasonic KX-TG5632M Twin Cordless Phone
Panasonic GigaRange KX-TG5240M Cordless Phone Logo
Top Panasonic Lands Phones Experts
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
