Sunbeam 699 Humidifier Logo
Question about Sunbeam 699 Humidifier
I have a sunbeam hunidifier model 699. I fill it with water and turn it on but no mist comes out.
Posted by dgh1360 on
5 Related Answers
Anonymous
SOURCE: Bionaire Bcm630
Same problem — junk.  Will return it to Sears (Costco was out).
Posted on Feb 05, 2008
Anonymous
  • 123 Answers
SOURCE: sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
Posted on Apr 21, 2008
Anonymous
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Posted on May 30, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: Need parts for Sunbeam ultrasonic
I see you have been waiting on a response for some time and I suggest you contact Sunbeam (if you haven't done it already) at their website for Canada:
Sunbeam Canada Customer Service
Hello...i have a sunbeam filter free warm mist humidifier,and i put the water in and turn it on but it doesn't seem to be working. All the lites are on but nothing and it's brand new too never been used.
Hi, have you given it a while? That humidifier usually takes about 10 minutes to get going. After 10 minutes or so you should be able to feel the warm mist coming out, and soon after you should feel a difference in the moisture in the air.
2helpful
2answers
I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
2helpful
2answers
I'd like to clean my sunbeam warm mist humidifier
if you mean by stone build up, you need a de scaler such as clr from any hardware store. let it soak on the crusty parts overnight the rinse well with water. toothbrush helps too.
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
1helpful
7helpful
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
10helpful
2answers
Sunbeam ultrasonic cool mist humidifer model 700
Good Luck.
Open Questions:
Top Sunbeam Humidifiers Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
