SOURCE: I have a 2002 ford
2002 Ford Focus Car Stereo Radio Wiring Diagram:
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: None
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): White
Right Rear Speaker Wire (-): Gray
SOURCE: 1999 ford explorer car stereo install
Heres the whole list. 1999 Ford Explorer Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Doors Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink (from the12volt.com) Best of Luck.
SOURCE: cobra external speaker....I have a cobra s500
The black wire goes in the external speaker and the red wire goes in the PA jack.
SOURCE: I'm looking for the wiring
You should be able to find them here:
http://www.installdr.com/Harnesses/Ford-Wiring.asp
I think that the key is to use the term "harness" when searching for this information.
I would contact Crutchfield.com and try to purchase a ready-made wiring harness for your vehicle. Hopefully they can sell you one without having to purchase a stereo from them. The harness will plug directly into the Transit's existing stereo plug and they you solder it to the harness that came with your head unit. This make your new head unit plug match the factory head unit plug so you don't have to make any modifications to the factory harness. Very good when you want to restore the vehicle to its orginal state.
I hope this helps. Good luck!
