Washing Machines Logo
Question about Electrolux Washing Machines
Electrolux 12141 Washer/Dryer When opening the door the clothes are really steaming. We haven't noticed this before, the machine approx. 2 and a half years old. Is this normal? Or is it something that has broken (i.e. thermostat). Cheers
Posted by jem_webber on
Anonymous
  • Electrolux Master
  • 3,361 Answers
Your exhaust vent is blocked causing the steaming affect.
Remove the exhaust vent from the rear of the dryer and clean it thouroughly before replacing. Make sure it is straight as possible with no kinks.
Posted on Jan 10, 2011
Electrolux washer always steams, even on cold setting
Try disconnecting it from the mains supply overnight to reset. If it still does it, you need a service call. It is likely to be the Control Board and they are expensive so need correct diagnosis.
3answers
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
1helpful
I have an IQ touch front load washer. lately I have noticed a mildew smell coming from the clothes and drum after washing. i have followed the manual and completed the refresh and comlete cleaning...
Water can remain in ANY washer after the load is done. With a top-loading washer, it's easy to leave the lid up so that the water evaporates. With a front loader such as yours, however, the open door can take space in your laundry area, so we usually close the doors. I suggest that you take a dilute solution of chlorine bleach and water and put it on a disposable cloth and wipe down the inside of your washer as well as the areas around the door itself and the part of the washer that the door closes onto. Once you've done this, leave the door open until the smell dissipates OR overnight. If you will get into the habit of leaving the door open for a couple of hours after you're done with your laundry, you will probably solve the problem.
I really hope this helps. If it does, please come back to Fixya and rate my solution.
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Cannot open the front door on an Electrolux ECO 7 kg front load washing machine. Feels as trhough the door clip has broken
I really did not fix the problem. I think the plastic linkage may have been broken and I was looking for a fixto open the door.
Thanks anyway,
Jim Charlesworth
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Hotpoint electric dryer
check your vent its probably clogged or kinked you need air flow to get rid of the steam
Wd63 washer dryer when complete when i open the door alot of hot steam comes out
your water supply to the machine has been turned off, or the triplewater valve has gone open circuit on the condensor solaniod if you have a multimeter you can test the valves unplug the machine from the mains and turn the cold water supply off , take the back panel off take 2 wires off at a time and test each solanoid they should read around 3800 ohms if you nget no reading on 1 of the solaniods thats you problem change the complete valve. good luck
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
