Hello
First disabel the lock and re-enter your own lock code. For this do the following.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
I don't have left and right arrow keys on my remote. Now what do I do????
Hello
What is the model number and brand name of your remote control? The above procedure given is to be worked with Philips original remote control, and it shoud work. OK.
Thank you so much . I bought a remote for the TV as it did not come with one. it's an RCA RCU4036A
i'M SORRY typo RCA RCU 403A
Hello
RCA remote control won't work properly with your set. Just select one [PHILIPS CL 034] model remote for your tV. It will sork with most brand of sets, including Magnavox and Philips. The code for magnavox with the above said model remote are : ............ 0807 0002 0502
0247 0919 0224 0430
0402 0408 0109 0715
Proceedings:-
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
You will get its manual including codes and proceedings alongwith it when you buy a new one. OK. Wish you Goodluck.
