Question about HTC Droid Eris by
HTC phone in safe mode, can this be fixed - HTC Droid Eris by
Posted by terrance_lee on
okeoma onyedikachi
  • 425 Answers
Hi, When you're done troubleshooting problems with your HTC Hero in Safe Mode,
you will need to go through steps to boot it regularly and remove it from Safe Mode.
To do so, turn off the phone. Then while its off, hold the Menu and Power until the phone boots. The Hero should then no longer be in Safe Mode
Start the phone and uninstall apps in safe mode
If your phone keeps restarting, or it starts up but does not display the Home screen, a recently installed application may be causing the issue.
When this happens, try starting up your phone in safe mode. In this mode, your phone does not run any third-party applications. Safe mode allows you to start up your phone successfully so you can uninstall any applications that you have recently installed or which may be stopping your phone from starting up correctly.
To start up your phone in safe mode, press the END CALL/POWER button and hold the MENU button until your phone restarts and displays the Home Screen. You will see "Safe mode" displayed at the bottom-left side of your phone screen. When your phone is in safe mode, follow the same steps in Removing installed apps to uninstall the third-party applications.
After you finish uninstalling the applications, restart your phone and check if the issue is resolved.
Hope it helped.
Thanks for using fixya....
Posted on Jan 10, 2011
Htc one sv stuck in safe mode volume buttons inoperable
Turn off the device. Remove the battery, hold the power button down for 5 to 10 seconds. Reinstall the battery, this should reset the device back to normal. Hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Jul 16, 2014 | HTC One SV
Get htc rhyme out of safe mode
How do you turn the HTC RHYME out of safe mode!
Aug 15, 2013 | HTC Rhyme
How to remove safe mode on htc salsa
I dont have a home butten u have to slide it up
Jan 19, 2013 | HTC Salsa Smartphone
Htc sensation stuck safe mode
This happened to me on HTC Sensation. I was able to get into my apps after a few attempts to reboot seems when volume is all the way down during a reboot it initiates the safe mode. this can happen, im told for many, reasons. Even if your volume controls are working fine.dust etc. although I followed the directions listed above I cleared the htc sense cache then re*stareted and all loaded just fine. I just had too do a little rearanging to my apps on home page . so I am pleased I saved a service call
Mar 27, 2012 | HTC Cell Phones
Put htc inspire in safe mode
Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional repair tools. They are free to consult, I hope that the programmers I recommend can help you.
Oct 20, 2017 | HTC Inspire 4G Smartphone
How do I turn off safe mode on my HTC Explorer?
how do i get the phone out of safe mode
Jan 12, 2012 | HTC Cell Phones
Htc stuck in safe mode
I can't install software's, I have problem with safe mode and one more thing my key button is not working. Get me solution
Jan 04, 2012 | HTC Wildfire S Smartphone
Safe mode on g1 wont go away
press the red phone button and choose turn off then press ok when the next window comes up and the phone will shut down.try and turn it back on wait for it to load up and you should be good to go
May 31, 2010 | HTC G1
G1 safe mode
Power the device off, while it is off press and hold the Menu button and the Red Power Button at the same time, when the phones boots back up the Safe Mode should be off. If this does not work a Master Reset may be required.
Dec 27, 2008 | HTC G1
HTC Droid Eris by Logo
2,265 people viewed this question
Top HTC Cell Phones Experts
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Marvin
Marvin
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
