SOURCE: stuck on last minute
I have seen a lot of these dishwashers burn out the control board, and usually the symptom is the timer not working or inability to complete a cycle. Most of the ones I have seen, you can remove the control board assembly and its pretty obvious where its burnt. If you can do the repair yourself, the board is about $150. Hope this helps!
SOURCE: Cleaning the filter / wash cycle not running properly
you need to put the machine on its front and look under it and you will see a black rubber it gos to the pump and to the drum well the drum one has to come undone with a flat head screw driver and if that's clean then put it back properly when you have done that and you have cleaned the pump out if the machine still done work then your pump has gone you will get one from ebay don't for get to wright down your model number ok good luck
SOURCE: Ran the dishwasher and the
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
SOURCE: not spinning
If the m/c is washing but not spinning, then u need to check the filter.
It is located behind the lower rear panel of m/c.
Remove panel and remove large black hose on the bottom of drum, there u will see the filter, remove and clean.
Refit and make sure the hose is on properly.Test.
If u have no drum action on wash or spin then u need to check the motor carbons, this can be done whilst u have the rear panel off.
If carbs o/k but still no motor action, then u prob have control board prob.
Plz rate my solution.
Thanks.
SOURCE: LG LDS dishwasher soap door does't open until you open main door
I'd try cleaning the soap dispenser mechanism as good as you can with forced air or water then pour oil on the hinged areas and wiggle it a lot!
I'd also put a big sign on it to remind me to put the soap in after I unload the dishes!
Hope this is helpful!
Good Luck!
