Question about OKI MICROLINE 520 Matrix Printer
I cannot stop my OKI 520 defaulting to NLQ when I am printing invoices/ on a new software system. Iniitally it went to the Utlilty level but now wants to go to NLQ which I do not want . Tried changing on the pad but it does not stay there unless I am doing something wrong. Any suggestions ? Billy Richmond
Posted by br09 on
5 Related Answers
Desmond Pillay
  • 40 Answers
SOURCE: oki 520/521 logic boards
Check if the Pico fuse is blown ? next to the heat sink on the transisitor array with the number 2025.if the fuse is gone than the fuse plus the 2025 transistor must be replaced.
Dezzi
Posted on Dec 31, 2007
headstrong
Pedro
  • 233 Answers
SOURCE: OKI MICROLINE 320 Turbo
1) First Disconnect the printer cable from the printer and computer, inspect the cable for damage
replace cable, if you have a different cable even better
2) Reboot PC and Re-install printer driver
3) if these steps do not work, it is possible there is a problem with the main board in the printer, sometimes, removing the board and re-installing it can help (dirty contacts inside)
but usually with problems like this is the drivers or cable
hope this helps
thanks for rating
Posted on Jan 18, 2008
Anonymous
  • 139 Answers
SOURCE: Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Posted on Jan 23, 2008
Anonymous
SOURCE: oki printer 3320 micromline
change to letter
Posted on Feb 22, 2008
Renierf
  • 97 Answers
SOURCE: Oki Microline 520 printing slow
Re-seat your Printhead. If problem persists Replace the Main Board.
Posted on May 12, 2009
Printing trouble, OKI microline 320 Turbo. All of a sudden it's not printing the right side of the invoice. I have no idea how to increase the printing area so this doesn't happen. Please help!
There are 3 competing controls. 1) Software 2) Printer driver 3) Front panel. Software control overrides printer driver. Printer driver overrides front panel. Your software settings therefore dominate. That said, you can choose to have the front panel settings "dominate." Those front panel settings may enable you to change margin widths. Even though this may be possible, you may well find the solution is within the invoice software's print setup where you may have to check some box to enable 11 inch printing or whatever is required. But that requires knowledge of the invoice software program. I am unable to determine if you are encountering a sudden failure of a system previously working. If this is a printer failure rather than a software configuration problem, you will have to check the okidata help.
Here is some reference material:
Okidata Users Manual ML320 ML321 Turbo Problem 1 My word processor files...
Apr 11, 2018 | OKI Office Equipment & Supplies
Using Win7 - switches to NLQ mode every time regadless of driver used - Okidata Elite (Microline) 520, Okidata Elite (IBM) or Okidata 520. Tried changing drivers - none other available for Win7. With the...
This is a SNIP of a rather LONG FIX:
Found here:
http://forums.windrivers.com/showthread.php?7080-RESOLVED-Okidata-Microline-184-Turbo
"Just purchased this thing and am running it a machine to print checks with (Win95, p1-200, 48 Mb ram). The Oki dot matrix printers don't give you drivers, they tell you to use the drivers from Win95 disk. Sure... (just lazy if you ask me :-) OK using the Oki Microline 184 IBM Turbo driver the thing works fine, EXCEPT that it *always* prints in NLQ mode no matter what the settings in the control panel, it just switches to NLQ before each print job. So... we switch to a "generic text" driver and it works fine that way EXCEPT that it no longer recognises the custom paper length (8.5" wide X 7" long) Now here's the wierd part... IF I switch back to the win95 driver, re-accept the custom paper size, print a test page (in NLQ of course), switch back to the generic driver, re-accept the the custom paper size, switch the printer to normal (non NLQ), and print it works fine with the custom paper size and non-NLQ mode until the next time it needs to print. The printer remains ON 24/7, so its not reseting itself. It just seems that with the Win95 driver there is no way to set it to print in anything but NLQ AND the generic driver refuses to keep the custom paper sizes in memory. Anyone seen this before? Never came accross this myself. I may just end up sending this thing back and getting an Epson or someting else."
AND THERE IS THIS:
"This is like going back to the dark ages....most of those old impact printers had dip switches to set things like default print quality. Additionally, Oki's usually came in two 'flavors'--plain Oki and IBM Oki. It's important that you install the correct driver between the two options..."
Anthony
Dec 25, 2017 | OKI MICROLINE 520 Matrix Printer
Print quality - what is hsd, nlq, utl, ssd mean on the printer
Hi Teresa,
These are just print quality settings
Super Speed Draft (SSD) - 435 cps. High Speed Draft (HSD) - 390 cps. Utility ( UTL) - 300 cps. Near Letter Quality (NLQ) - 75 cps
Hope this helps!
Please don't forget to rate
Jan 21, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 3320 doesnt stop in the right place for next invoic
Look on preferences, check if A4 is used for paper layout...
Jun 09, 2009 | OKI MICROLINE 3320 Matrix Printer
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Your printhead alignment is out thats why it prints slow
Jul 17, 2008 | OKI MICROLINE 520 Matrix Printer
OKI 520 ELITE
Kindly check the DPI settings . May be more DPI this time.
Best Regards
Rafique
Feb 19, 2008 | OKI MICROLINE 520 Matrix Printer
Trouble with changing the size of letter
Press the select button so light would go off than press 2 buttons marked menu than press print,this will print out the menu settings .When done press the group button till rear group prints than press item till page lenght prints,now press the set button till the desired page length is reached,than press exit button to save setting and exit from menu.Power off the printer then power back on should be ok .Hope this helps.
dezzi
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
Double Printing
check the printer drvier properties and make sur the defaulf is not set to print 2 copies.
Jun 14, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MICROLINE 520 Matrix Printer Logo
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
