HP LaserJet 4250n Printer Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having printer quality issues with hp laser jet 4250n. All the words are blurry.
Anonymous
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Jan 17, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
42
Questions
0
Helped
9211
Points
103
Replace the Fuser, it is behind the back door Part # RM1-1082.
Remove back door and push two blue tabs on fuser, remove and replace.
My HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on
Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
The red color light is always blinking on laser jet F4200? May i know the error plz?
Is there a waste-bin in this printer? I had the same issue with a Samsung printer, and there was a toner-waste bin that I needed to replace by an empty one. It also could be a waste-bin of the staples or warning to refill the stapling unit.
I have a 49.4C02 error on our HP Laser Jet 4250n. How do I fix this?
I have proble 49.4c02 as can solution because I liven in cuba
MY Mail is [email protected]
1helpful
2answers
We have a HP Colour Laser Jet 3600n. We have
nope...... the problem as you rightly poit out is the cartridges, most refills are poor quality and dont last, but the real ones are expensive but very rarely cause issues. If one colour is dodgy the entire colour process fails, print a square of each colour to determine which colour cart is the issue and complain to seller, 99.9% of print quality issues with these HP's is due to non gen toner....not much you can do, expensive is colour printer fullstop.
2helpful
2answers
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Printer problem
First remove the control panel from the machine and make sure that the cable is seated well to the panel and the control board. If they are remove both cable ends and reseat them.
3helpful
Blank display
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
k24674
Grand Canyon Tech
Grand Canyon Tech
