We had a similar knocking but our problem wasn't as easy as just tightening the bolt. We had to pull off the flywheel itself and check the square connector that connects the fly wheel to the axil. Unfortunately ours has been worn down so the flywheel would never fit properly to the axil without knocking due to the space that has been created. Option number 1, call Schwinn and tell them you need a new flywheel. Option 2, pull some tools out of the garage and go mcguyver on it.... Our solution involved a welding torch.
I just fixed the problem on my 430. Somewhere on this forum someone suggested that the dollar size cover on each side of the flywheel cover be removed and the bolt tightened. You will need a socket wrench. It took less than 5 minuted and whamo. Problem solved. Thanks to the individual with that input. Good luck
