2wire 1800HG Router (RG1800HG00) Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No lights. no power. does not work at all. - 2wire 1800HG Router (RG1800HG00)
Tomislav Marinovic
Level 2:
  • Expert 205 Answers
  • Posted on Jan 10, 2011
Tomislav Marinovic
Expert
Level 2:
Answers
205
Questions
0
Helped
77222
Points
569
Try to change your power adapter. if still no result - yes - it's dead
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Spotlight wiring
Copy following link for troubleshoot resources and tips to get power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
The lights don't have bulbs?/ This is not clear.
Buy new bulbs.
Be sure to unplug power pack when working on lights, or power pack can fail.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1996 Camry reverse lights don't work
Check if you are getting power to the reverse light switch. Turn ignition on, disconect terminals to the switch and check for power on the positive terminal using a light bulb or a test meter whatever. If power is there jumpthe 2 terminals and check if light backup light works. If it does replace switch. If ther is no power at switch check wiring from fuse box. If light does not work when switch is jumped check wiring to back.
Ra Rodeo Tail lights not working have power at fuses but loss of power at lights?
Are you getting voltage at tail lights
check earth connections too.
4helpful
Tail lights not working. fuses look good, brake lights work, hazards work, but running lights don't- gmc sierra 2500
do the front marker/park lights work if not you could have a bad light switch on the tail light side of the switch.you need to check the brown wire at the back of the truck in the wiring harness as this is the tail light wire that feeds the bulbs.if you have power there then you will have to check for power at the socket,if no power at the socket but were you check the wire then there is a problem between the two that you will have to check out.if there is no power when checking the wire then you will have to check for lose of power between the switch and rear wiring.make sure the fuse is good by using a test light and not by looking as sometimes they look good but don`t work.
My right rear fog light does not work, any ideas why? the other lights work fine, and its not the light bulb
check for power at the light, if no power and fuse ok check for power to switch and power coming out of switch when switched on if there is power to switch but no power out from switch when switched on, switch is faulty, if there is power from switch, wire is broken between switch an fog light
2helpful
My power mirrors are not working & misc interior lights out
yea sounds like a loss of power. start by checking all! all the fuses.
9helpful
Aquos has the power light and OPC light flasing but nothing works
First turn on power light stable at all?Power and OPC lights well flash,but push on/off power button do this couple times after the Power and OPC flashes well backlight come back on well work.This problem very common is Sharp tv.
Were is the rpo relay located . my regular brake light don't turn on. i check light bulb r ok. there is no power to going to the back lights
RPO relay?? no power to rear lights or just brake lights?? is there power at the brake light switch? does the center high mounted brake light work? if the center light works the the switch is good. fuse #13 powers the brake lights (all)
Brakes lights don't work, only 3rd brake light does.
If your third brake light is working, then we know it is not the brake switch. Get a test light and check to see if you have power at the light socket. If power is present possible bad ground. If no power, check connections inside of the trunk. Also choose a spot just behind the back seat to be sure that power is on the brake light wire, this will check for possible break along wire.
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
