Hey Kidd... I don't know if this will solve your problem, I found it in a Microsoft Forum:
Anyone recieving the 8E5E0247 Error trying to login to Windows Live Msgr and/or Windows Update who has an INTEL processor & Hard Drive over 300Gb must install the Intel Rapid Storage Technology Software. This will solve your problems. http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2101&DwnldID=19607&ProductFamily=Chipsets&ProductLine=Chipset+Software&ProductProduct=Intel%c2%ae+Rapid+Storage+Technology+(Intel%c2%ae+RST)&lang=eng - * - * - * - * - Windows Live Messenger giri? yapmak yada Windows Update kullanmak isteyen fakat 8E5E0247 kod numaral? hatay? alan, Intel i?lemcili ve 300 GB ?zeri kapasiteli harddiskli bilgisayar? olan kullan?c?lar?n Intel Rapid Storage Technology yaz?l?m?n? bilgisayarlar?na kurmalar? gerekmektedir. Bu yaz?l?m ya?ad???n?z problemi ??zecektir. indirmek i?in: http://downloadmirror.intel.com/19607/eng/iata_enu.exe
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Since Sun Cellular does not have specific settings for your phone for an automatic configuration, you can still connect to the internet by configuring your device manually. You just have to look for internet settings in your phone and input the configuration as indicated below.
SUN GPRS Settings (HTTP & WAP)
Connects to:The Internet Access Point:minternet User & Password : Primary DNS:210.23.234.65 Secondary DNS:0.0.0.0 IP Address:
SUN MMS Settings
Connects to:MMS Connection Access Point:mms User & Password : Primary DNS:0.0.0.0 Secondary DNS:0.0.0.0 IP Address:
Short for Domain Name System (or Service or Server), an Internet service that translates domain names into IP addresses. Because domain names are alphabetic, they're easier to remember. The Internet however, is really based on IP addresses.
Every time you use a domain name, therefore, a DNS service must
translate the name into the corresponding IP address. For example, the
domain name www.example.com might translate to 198.105.232.4. The DNS system is, in fact, its own network.
If one DNS server doesn't know how to translate a particular domain
name, it asks another one, and so on, until the correct IP address is
returned.
Selam belki telefonunuzu azaltilabilmektedir telefonunuz
aç?k ve telefonunuzun ?arj pin temiz .. o arayüzü, mikrofon kulakl?k ve
?arj pin ba?lant?l? oldu?unu ... iyi handsfree telefon hala fixya
güvendi?in için te?ekkür .. azaltilabilmektedir olup olmad???n? test
etmek için kullan?n ....
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
your connection won`t drop after this.
(you can use this to solve your problem.i had same problem as you and when i am searching i found.but your mp3 player model isnt correct becasue there isnt any sa2515.if u want u can try this. http://rapidshare.com/files/235570117/philips-gogear.rar)
Make the Ip address similary to the router, example 192.168.1.25 should work. SUbnet mask will then fill in automaticaly, just leave it then Default gateway will be the routers IP. 192.168.1.1 the dns server would be the ip of your internet provider. I would leave it blank at first, see if it will work then. If not, then ask your service provider for it. If they give u a number, then you will have to go into the router properties, and change the dns and stuff like that in there aswell. good luck
