One thing you can do that should help you without to much expense is to in stall a dual soft seated check valve directly upstream of your air gap. This should help quiet it down.
One other thing you can try if your R.O. system is a small under counter unit that has the r.o. membrane and filters mounted in a moveable unit is to turn your r.o. faucet on and tilt the filter unit forward at about a 45 degree angle. Do this at least ten times and see if that helps with the noise. I have seen several smaller units that have a automatic shut off valve that will chatter or cause other problems if this is not done. Hope this helps you. Thanks
