Question about Washburn NEW PRO WASHBURN ACOUSTIC GUITAR +FISHMAN ISYS WD20SCE
My guitar is great I love it but the built in fishman isys tuner is not tuning my guitar properly and when it tells me my guitar is in tune it is really not at all. Is there a way to fix this ? Please help me out ???
Posted by go_mustangs_ on
Anonymous
    New Friend:
Hey There,
If its adjustable its worth checking if the Pitch of the tuner is set right (normaly changed by a + & - button) Any normal tuner should be set to 440 which is standard Pitch.
Hope this is of any help
Posted on Feb 28, 2011
How do i adjust intonation on a peavey predator plus exp?
To adjust the intonation on a guitar you need the following. ..
a electronic tuner
and a small philip screwdriver
when you tune a string say low E you play the note open and adjust tell it's in tune
then to intonate play the low E at the 12th fret
producing a Harmonic, view the tuner it will be sharp or flat,
turn the small philip screw on the bridge adjustment
it only takes a small turn one way or the other so go slow
once the string is tuned at the harmonic note check to see if it's in tune played open, keep tuning and adjusting tell the strings are in tune open and at the 12th fret on all six strings
once intonation is set properly the guitar will sound better
really hope that helps?
Mar 15, 2015 | Peavey Music
How do I set the tuner to tune at different keys?
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
Mar 06, 2015 | Music
Don't know how to turn on tuner
put a battery in your guitar. It goes in the space at the bottom, usually where you connect your cable to your amp.
Then hold the guitar as you usually would.
Look for a little board with buttons on the side of the guitar to turn on the tuner: )
Mar 27, 2014 | Ibanez Talman Acoustic/Electric Guitar
Fishman isys
try it on another guitar
Jul 24, 2013 | Music
How to tune Fishman Prefix Premium blend
If it is the standard ISYS try
http://www.fishman.com/files/isys_preamp_system_user_guide.pdf
Jun 30, 2012 | Washburn NEW PRO WASHBURN ACOUSTIC GUITAR...
Ive got a dean vedetta guitar with floyd rose pickup... every time i tune it, it goes off in a while... also my string levels are very high which makes it difficult to play... i dont have much knowledge...
Some tuners have a weird mode that one presses the button once and the tuner will pass the audio until it times out, then tuner and audio stop. Two presses kills audio while tuner works for a time period and then goes dead. A third press enables audio to pass for normal playing. These are confusing compared to other type built in tuners. If you have one of these read the CONFUSING instructions carefully...
May 07, 2011 | Dean Vendetta XM Electric Guitar
Hi, i have a acoustic guitar but i do not know how to tune it with the Matrix Chromatic Tuner SR-1050
That tuner has a built in microphone to listen for your guitars sound. Turn it on and set is close to your guitar as you tune it.
Mar 01, 2011 | Matrix Auto Chromatic Tuner Sr1050
Washburn NEW PRO WASHBURN ACOUSTIC GUITAR +FISHMAN ISYS WD20SCE Logo
933 people viewed this question
Top Washburn Music Experts
Bruce Showalter
Ron Rak
Ron Rak
David Gust
Are you a Washburn Music Expert? Answer questions, earn points and help others
