Question about Samsung Microwave Ovens
I want to set the temprature of samsung microwave oven at 121.5 degrees for sterlisation. Is it possible, if yes, how?
Posted by r_chimra on
specialistel
    Brigadier General:
  • 8,909 Answers
It is possible to set the convection oven to attain temperatures of 120, 130, 140 etc.
121.5 is a bit to accurate!
To kill fungal spores any more that 121 degrees celcius will be fine, so set it to 130 and after 10 minutes that should have sterilized the surface of any items inside the cavity.
Maybe aquire a digital temperature as a guage for this purpose?
Hope this helps.
Posted on Jan 10, 2011
How to set degrees
Microwave ovens can't be used to bake cakes. One needs a regular convection oven to make things that rise.
Apr 24, 2014 | Microwave Ovens
Set degree 160
Change mode to HI using control panel.
Jul 04, 2013 | Samsung 80092 Microwave Oven
Try to set the clock on my samsung MR1032BB microwave in my 2003 Georgie Boy Pursuit motorhome. It sets and then after 3 minutes it starts beeping and gives the numbers 8888 and 6666 and you can't...
Yes it is on recall and asks that you don't use it, as well as unplug unit if at all possible, and if not, leave door ajar and don't store anything in it.Here's a number to call at Samsung.
Owners may contact Samsung at 800-932-3837
Aug 22, 2011 | Samsung SMH8165STE Microwave Oven
Does this type microwave oven has any fuses
Yes, inside the cabinet... be careful in there...!!!!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 15, 2011 | Samsung SMH9151 Microwave Oven
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Is there a 90 degree power cord available
yes, i buy them at home depot, they are a bit rare, 90 degree extenision cords. usually they only carry one type. you can wire it into your microwave, or use as extension cord. this is good for tight spaces, like beside bed or wall.it is also safer rather than pressing on plug to wall.
Nov 03, 2009 | Sharp R-425LS Microwave Oven
How to set temperature
hi friend,
The microwave oven per se, does not have a temperature. The microwaves that are generated simply heat up the water molecules in the item that they hit. So, the maximum temperature, I guess, would be 100 degrees C or 212 degrees F, the boiling point of water.
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Samsung MW4699S Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Ekse
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
