Question about YouTube Videos
Hello...I have an issue with my speakers. My husband ran our speaker wires from our computer to our stereo and I can't get it to produce sound please help!!!
Posted by shellnae on
Anonymous
    Scholar:
    New Friend:
  • 34 Answers
Be sure you plugged the plugs into the right ports on the back of the stereo.
From the computer: ensure you plugged the cables into the Auxilary Out, or Out jacks of the sound card.
On the stereo: ensure you plugged the cables into any open set of Auxilary In jacks.
Once you verify your cables are plugged in correctly, verify the input on the stereo is set properly. Set your stereo's source or input to "Auxilary" or "Auxilary 1 or 2." This allows the stereo to pull input from the cables running into the appropriately selected Auxilary source.
That should help hopefully.
If you still can't get sound, double check your computer's sound card settings and be sure the sound card is working properly.
Posted on Jan 10, 2011
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
My Lexus 2004 RX330 only has sound from the passenger speakers. Balance to left produces no sound. Balance to right produces sound on passenger side only.
Just check the wire..it is clear a wiring issue ..It is either from the plugs or the wire itself has a break on ..To be sure just attach a speaker to the left out and see if it has signal ..than re-wire it just to be sure..If you insert another control speaker or anything ..just to see if it has signal ..and nothing gets on the left ..check the settings ..and reset the player ..If this will not make a stereo out ..than the left channel has an issue and need to be checked..Some has separated amplifiers patch and can go bad in just a channel ..but ..usually it is just the wire.. (If you have an amplifier connected ..check it too for settings ..and see if the balance is not all to the right ..)
Aug 09, 2011 | Car Audio & Video
Hello, My rockford fosgate in dash unit is not
Are your rear speakers smplified or ran directly off of the radio?
Jul 29, 2011 | Rockford Fosgate Stereo Audio+video Rca...
Woofer 4650 carcit digram
Establishing computer speakers includes networking to the devices from where media from be derived either as computers stereos of media players. First, the speakers require connection established between each component sound producing device that has an impression in generation capacity. Second, the speaker device have a box usually the woofer as central area with power cuicuit features. Connectable cables are power cuicuit related expected to extend from the woofer to the power outlet. Also, the woofer board would require as last connectivity, the cable attacchment to the devices that produce sound either as stereo music medis players, digital media displayers among mentionable media devices.
Feb 14, 2011 | Creative Labs MegaWorks THX 550 Computer...
No sound dual xhd6420 92 accord lx
my brother has a 1993 Honda accord and had the same issue, we put it different speakers and it worked fine, don't know what the problem was but it worked
Feb 12, 2010 | Dual Electronics XHD-6420 CD Player
New stereos produce no sound from front,
check the wiring behind the in-dash the wires are white n greay make sure that the lines on the wire r hooked up from harness to harness n the solid wire r 2 but it could be that ur door speakers are blown 2...
Jun 17, 2009 | Sony Car Audio & Video
Speaker produces sound even when the zone is off
Since the Pyle speaker is a 4 ohm device, it's likely that when you have other zones on, the change in the impedance will affect the volume. Check to see what impedance your other speakers are (standard is usually 8 ohm), and if your tuner has impedance matching for your zones. If it does not, that's most likely your issue. You could get an impedance matching transformer at Radio Shack to resolve this issue. Please rate my solution, thanks.
Apr 17, 2009 | Pyle PWRC82 Main / Stereo Speaker
Sound only one of two speakers
The wire/cable to one of the two might be frayed. If they are a fixed cable they may have been pulled to hard. If they are removable cables, check they are plugged in tight. Tight.
Speaker wire might need to be bought. Depends on what kind of speakers they are are they big square home stereo speakers? or tiny computer speakers.
If the sound is coming in and out, it is a wire issue.
Feb 11, 2009 | Dell A215 Computer Speakers
Speaker Sound Issue with 2 of the 4 speakers
Try this, I work in the sound production busines. Your audio CDs are not designed for Quad listening, they are stereo. If you put a game in you will hear all 4 speakers.
Aug 24, 2007 | Dell WL6000 Computer Speakers
YouTube Videos Logo
55 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Carlo Barzo
Carlo Barzo
Dhiraj Dubey
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
