Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop.
1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information.
2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has.
Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use.
3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside.
4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive.
5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution
Good Luck
You should take a risk for apart the laptop.Click on following bellow link for apart
http://www.insidemylaptop.com/take-apart-acer-aspire-5520-laptop/
It is not the same model ,but you can apart easily, through this help.
Hope this helps.
Hi. Thanks for your question.
Please see this video to see how to remove DVD drive.
http://www.youtube.com/watch?v=fyZRRjgr5ME&feature=related
Please note you can skip all the previous steps. Person shows how to remove DVD drive at 4:11.
Battery should always be removed before any repairs on laptop.
Good Luck. Please do not hesitate to ask more questions if this is needed.
Thank You for using FixYa.
Aspire 5510 CD/DVD Drive removal
There are 2 screws holding in the drive.
1. Access rear screw by removing the bottom centre cover over the WiFi/TV Cards,
2. Angle in a philips screw driver over the TVCard connector, to centre rear of drive. Use a torch..
2. Do keyboard removal- remove 3 screws holding LCD on, tilt lcd over backward, remove cover with power button by lift up from lcd side.
3. Remove 2 screws holding keyboard. CAREFULLY slide towards lcd then flip keyboard over.
4. Remove 2nd Screw holding Drive found in position of G key, thru circuit board to drive.
5. Remove by sliding out Drive. Replace. Reverse to put back togeather.
These drives seem to fail often. Maybe just replace the screw under keyboard & leave a label under to say where dvd drive screw is for next time.
Refer link for Aspire 5510 manual from acer service.
