Mitsubishi VS-50605 50" Rear Projection Television Logo
Posted on Jan 10, 2011
No image but is sound - Mitsubishi VS-50605 50" Rear Projection Television
David
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jan 15, 2011
David
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
1575
Points
22
1helpful
I want sound configuration off jumpers
you can setup the sound jumper setting in the help of this image here is the image for your sound configuration.
Thank you for using Fixya.
Regards
Manish
3answers
TRV22E
Please provide the model and the make
1helpful
All of a sudden I have no sound on my Inspiron 1525..I have been having problems with this model since I bought it. I would like to try to reset it to the factory settings but don't remember how. ("factory...
check if computer is mute, check in sound properties if speaker headphones is selected, check if sound device is detected in device manager. try uninstall reinstall sound driver. to perform factory image, press F8 up to 10 times during the DELL LOGO, select repair your computer, select language then click next, click Dell Factory image Restore.
9helpful
3answers
I have managed to put a lock on my memory card in my camera... (it is on protection mode and dont know how to get it off as i want to delete all the pictures on the card. I have the old pentex optio wpi...
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
Dec 02, 2009 • Cameras
Need a small sound board for my Samsung TV
If the sound is distorted, then you need to replace Sound board. If you do not have picture and sound, it has nothing to do with sound board.
There might be millions of reason and depends on the make and model of the TV.
On most of the samsung TV's, such problem might be due to defective Circuit Board. It can be replaced or repaired.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
No image and sound on the rca hdtv 50' power button flashing
sounds like a fly back problem
have a qulifyed tech check this out its high voltage leaking you are hearing.
esp if its a sqweek hiss sound.
No image
sounds like the power supply has gone down poss. one of the electrolytic capacitors. common problem if the lampunit does not work
1helpful
EasyCap usb adapter sending images only from vcr. No sound.
while i preview mode there is no sound only image. when you record then playback sound is there.
2answers
DSC P51
There is a seperate microphone to do that. Usually when the CCD imager is bad it cause a white screen to appear or the colors are distorted in the view finder.
I would take it into a camera shop and see what they say unless the battery hasn't been replaced recently.
Sony tv with no image
When i turn the tv on there's no image and the red light blinks twice each time, but no sound or image or any sign of anything.
Please help me with this problem, my tv is a sony kv-25 with more than 10 years of age.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
