Question about Samsung Digimax L830 Digital Camera
Samsung L830 camera. I try charging it but the light on the charger is orange and blinks and does not charge the battery, ( instead of being red and charging)
Posted by reshikar1 on
Dou dou
    Master:
  • 340 Answers
Try another SAMSUNG L830 Battery to see is it anything wrong with the battery or charger, and get a new one.
Posted on Jan 10, 2011
  • Johnpush Dec 25, 2012
    really nice one
Does the battery have to go in a charger for charging
lila, yes you have to put the battery on the charger to charge the battery, if not the charger wont charge anything, after you put the battery on the charger hold, before that don't forget to equalize the pin charge with the battery there was a marking or emboss note negative pole and positive pole for the battery fit on it charge, then you can go for the electric plug. For additional note there is light indicator green for full battery, orange for the half battery energy and the last one is red light blink for the on going charge the battery. i hope it help, remember safety first.
Nov 11, 2015 | Samsung ST66 16 MP 5X Compact Digital...
Hello Sir / Madam, I've got a Samsung Camera L730, 7.2 mega pixel, the problem is while charging, 1st it showed red LED light ( as usual ), then immediately an orange light starts blinking (as per...
Do you have change a Samsung L730 battery and to see if it can be charged? If you charge the battery in camera. It seems something wrong with the build-in charger core. If the camera all are OK beside charge battery, you can charge your Samsung L730 battery with a battery charger, and if your Li-ion battery is over discharged for a long time, it's bad for it. As your camera has been used for 2 years and it maybe not in warranty. To change build-in charger core should be expensive.
Apr 29, 2011 | Cameras
When i plug my charger into the camera, it stays red for 1 minute, and then continuesly flashes orange, and doesnt charge, anyway i can fix this?
The problem appears to be in the rechargeable battery itself, I would replace the battery but not until the old one is checked first at the camera store.
Jan 13, 2011 | Samsung Digimax L830 Digital Camera
When charging my camera the charger light flashes red, green, orange and then it goes off. What does this mean?
battery issue try changing the batt they are not taking the charge pls replace if they got weaken or aged
pls rate me fixya if it helped
Mar 09, 2009 | Samsung Digimax L830 Digital Camera
Light on my samsung digtal camera charger is flashing orange and
pls checck the batt it is not taking the charge they are weaken and old pls ccheck it
pls rate me fixya for this if u like
Jan 30, 2009 | Samsung Digimax L830 Digital Camera
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
On the samsung p1000 digital camera charging is proving a problem. An orange light keeps blinking when the charger is connected and the camera remains uncharged and will not switch on
had the same problem! brand new camera, never had it switched on and it just kept blinking.
took battery and card out, put battery in then tried to charge. same orange light.
put card back in and took battery out for min and replaced, red light is on now!
hoping this has done it. will try camera in few hours!
Nov 21, 2008 | Cameras
L830 wont charge
it is possibly the battery itself. i have a two batteries for this camera one of them has this problem orange flashing light and doesn't charge and the other works fine. You might need to get a new battery. Good luck
Oct 11, 2008 | Samsung Digimax L830 Digital Camera
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Camera not charging
i got the same problem...it means battery is somehow discharging instead of charging..better get an external charger and remove battery from camera after every use.
Aug 08, 2007 | Samsung NV10 Digital Camera
Samsung Digimax L830 Digital Camera Logo
513 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
