When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Hi, I believe the cause of your washing machine's "rocking" problem is the result of the machine not being properly balanced (on all four legs). Let me explain. On the bottom of your washer and dryer, are four "adjustable" legs. These legs screw up or screw down. If you adjust these four legs so that the washer is perfectly square with your floor, your rocking problem will go away. This should do the trick. Good Luck!
