Question about Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went to the home screen, highlighted the "window editor" choice, and froze all over again. the (-) ) trick no longer works... help?
Posted by kelsers on
  • kakima Jan 10, 2011
    Press and hold left-arrow, right-arrow, and 2nd keys, then press and release ON. Does this do anything?
Anonymous
    Novelist:
  • 100 Answers
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Posted on Jan 10, 2011
2answers
TI-89 Titanium completely frozen (Tried all reset methods)
Press left and right arrow and 2nd keys simultaneosly, hold it and then press ON. Release all keys at the same time and you will reset TI 89 Titanium.
Or, type diamond key simultaneosly with + or -
(plus or minus) key to resolve dark screen.
1helpful
2answers
TI-89 Titanium screen frozen at apps menu
Remove the small memory battery, and then remove one of the four AAA batteries, then while holding down the APPS button reinstall the AAA battery and then it should say waiting to recieve operating system then hook it up to your computer with the silver connect cable and then on the computer send the operating system to the TI89 Titanium, and wait for it to install completely and it should work.
How to un froze the TI-89 titanuim will not turn off.
My TI-89 Titanium is stuck on the main screen and no matter what button i press nothing happens. I have tried changing out all of the batteries and nothing is working.
Hi
when you turn on the Calc press the 2nd button and if the busy indicator is on its and hardware problem or if none of the keys is working
let me know if you want to fix
[email protected]
Jack
3helpful
My TI-89 Titanium is frozen on a table setup window, and i can't do anything to get out of the screen. when i push any button, the cursor will blink once, but nothing happens or changes... Is this fixable?
This might be fixable - first try 2nd + On or Diamond + On. If those don't fix it, you'll need to reset your calculator. The quickest way is to pop a battery out of the back and put it back in. It also works to press Left + Right + 2nd + On all at once. There's a good chance you will lose anything unarchived with the latter method, so do the battery first.
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
1helpful
Dark screen, no blinking cursor
press 2nd and the down button (hold down button)
2helpful
Ti-89 Titanium froze
Try pressing the "on" button.. simple i know but I tried cancel, quit, esc, off everything.. but pressing the on button worked..
Occa
1helpful
2answers
TI 89 Titanium
Well the best solution is to stop making more problems
Texas Instruments TI-89 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Filipe Polido
Filipe Polido
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
