Question about Frigidaire PLEB27T9DC Electric Double Oven
Tried self cleaninging oven feature and now the oven wont unlock. How do you unlock the door?
Posted by melissa178 on
D. Floyd Kolb
  • Frigidaire Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker
Posted on Jan 10, 2011
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
    F90 Maximum oven door unlock time exceeded.
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
    2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
    3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
    4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
    5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
    6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
    7. If all situations above do not solve problem, replace EOC.
    F90 is a door lock code, Try this...
    unplug the range.
    wait 1 minute.
    turn the range back on,
    then while holding in on the oven door.
    start another self clean.
    wait 2 minutes.
    then cancel the self clean.
    do not release the door until the door lock light goes out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    GE Electric Double Oven Door Will Not Unlock
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
    My self cleaning oven will not unlock
    i would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
    May 11, 2008 | Whirlpool RBS275PD Electric Single Oven
    How to user self cleanning feature for oven
    my oven is on f 9 cant turn off and get oven door to unlock
    Feb 17, 2008 | Maytag CWG3100A Gas Single Oven
    Self cleaning lock
    well i don't know how long its been off but most have a safety feature that wont let the door open till it senses its safe can take an hour if its not malfunctioning reply and let me know how long its been
    Jan 20, 2008 | Ovens
    Door Lock
    som times u haf to push on the door the move the lever
    Apr 13, 2007 | Thermador SMW272 Electric Double Oven
    Frigidaire PLEB27T9DC Electric Double Oven Logo
    262 people viewed this question
    Top Frigidaire Ovens Experts
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    Alan Chouinard
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
