You are trying to install a printer but can't do so because of the Error 0x000003eb then you are at the best place as now we are continuing to discuss how to correct this issue. The error note doesn't give you much data as it just tells unable to install the printer and gives you the Error 0x000003eb.
If you are trying to install a printer but can't do so because of the Error 0x000003eb then you are at the right place as today we are going to discuss how to fix this issue. The error message doesn't give you much information as it just says unable to install the printer and gives you the error code 0x000003eb.
Method to fix Error 0x000003eb:-
1. Make sure Windows Installer Service is Running.
2. Perform Clean Boot.
3. Registry Fix.
4. The FULL solution is here-->
Error 0x000003eb
Error 0x000003eb is usually caused by wrongly configured system settings or different entries in the Windows registry. This error can be fixed with this blog.
