Question about Vicks V150 Humidifier
My humidifier just stopped working last night. the power light still comes on, but no steam is produced. i always add a bit of salt and clean it everyday. is there anything else to try or is it just dead??
Posted by medeous on
5 Related Answers
Anonymous
SOURCE: Reset light comes on, unit stops operating when tank is full
I was up all night with this since I just purchased it yesterday and I wanted to be certain that there wasn't some simple alternative to returning the humidifier since the reset light keeps going on immediately after I turn the unit on AND I've already followed all the directions to the T. Believe me - I was ready to return it cause ain't no 38.99 worth me doing all this tinkering and trying to figure out why they couldn't make the unit correctly cause apparently A-LOT of people have this problem. If it wasn't for my three children being so ill including myself getting sicker going out to purchase the humidifier and I was trying to avoid going back out to further compound my illness----I WOULD have just returned it. MAYBE I still will return it. ANYWAY, here's the deal: the water in the tank SHOULD flow into the boiling chamber where of course steam rises from there; however, the WATER VALVE in the CAP to the water tank does not allow any water to flow into the boiling chamber because it is so tight. The reset light goes on as if there was no water in the tank because of course, the heater is on, but no water is getting boiled because the water can't get in. There are a few things you can do. First: the water valve is a little stick and a spring within a piece of rubber that can be slipped out of the cap (this is what I chose to do). Now the water flows easily and even with the unit set to high, there is no problem. It just works. Second: You could remove ONLY the stick and spring from the water valve's rubber piece. This would work if the hole in the rubber piece happens to allow steady water flow (mine wouldn't). Third: you could probably do some cutting til you were satisfied with the results.
Posted on Feb 01, 2009
Anonymous
SOURCE: vicks humidifier
Even though you change the water every time, if it's like ours you will still need to clean it with vinegar about once a week. I have a container that the insert portion (filter or whatever it's called) will sit in and has just enough room to pour in 4 inches of vinegar. Let it sit for about 10 to 20 minutes and then run water through the part where the mist comes out while holding your hand over the bottom. After a few seconds allow it all to run through. Continue and shake it really good and continue on until it is clear. I was AMAZED at what came out the first time I did this and part of the time I used distilled water. Hope this solves the problem.
Posted on Mar 01, 2009
Anonymous
SOURCE: no mist coming out at all
on the box there is a number for questions or comments : 1-800-VAPOR-1-2 ( 1-800-827-6712 ).
Posted on Apr 12, 2009
Anonymous
SOURCE: Spitting noises and gushing water
Sounds like it needs a good cleaning. Use 1/2 c. regular vinegar to 3-4 cups regular water and let soak for a few hours. Remove and tap the steamer to remove caked up sediment. Should be ready to use again. If it's a little slow, add a small pinch of salt.
Posted on Feb 11, 2010
Anonymous
  • 56 Answers
SOURCE: I have a Humidifier and it used to provide my room
i will like u to go through the manual and check the settings of the humidifier, if no change take place, look 4 a good repairer to fix it up 4 u
Posted on Apr 07, 2010
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I don't think that my vicks V150 Humidifier is working correctly? I had it on all night and the orange light never turned Green and only a little water evaporated? I think that i remember it turning green...
Mine never turns green, always stay orange when on. As for the vapour, i add a little salt to the water and it works wonders, just about a tsp... good luck!
Jan 25, 2011 | Vicks V150 Humidifier
My humidifier is not working. I have cleaned the heating element. When plugged in the green turns on but that is it. The elements are not heating up to begin the vapor process.
Add salt. No more then 1/2 to 3/4tps max depending on the mineral content in your area.
The unit has two electrodes dipped into the water. Since water its self is none conductive without heavy minerals such as iron and such. You will have to add a small amount of salt until current starts flowing between the electrodes. I suggest a small pinch of salt each try until it produces the steam effect you desire.
Dec 22, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Dec 24, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No steam output
Dec 06, 2009 - found solution: if unit is truely clean, unplug unit then mix about a teaspoon of iodized salt (table salt) to the water. Reconnect unit wait about 1 - 2 minutes, unit will start to make a grinding sound but shortly after steam will produce.
Nov 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No mist coming out at all
Mar 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No steam comes out
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Mar 01, 2008 | Vicks V150SG 1 Gallon Humidifier
Vicks V150 Humidifier Logo
143 people viewed this question
Top Vicks Humidifiers Experts
Brad Scarpetta
Paul Carew
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
