SOURCE: Sansa Sandisk 4GB MP3 player problem transferring songs from cd too mp3
Hello sunbeem96678 ,
Have u copied all the songs to the audio folder ?
SOURCE: music downloads
Right-click a file and check properties to see if it is hidden. Unclick the "hidden" box and click OK. See if it copies and plays. (You can do this right on the Trio if you can see its files on your computer. It should show up and play right away.) If this works, highlight all the files and do the same to unhide the whole group.
SOURCE: Sansa scan disk mp3 player
guest - you must have Windows Vista - it's not compatible
tooth -
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
SOURCE: Computer doesn't recognize MP3 player -
I had the same problem, all you have to do is first turn on the Mp3.Then go to settings. Then go down to USB mode. It will probably say, auto detect.But instead scroll down to MSC. If that doesn't work try MTP.
