What the troubleshooting guide suggest is to turn off the camera and turn it back on which sound like what you have been doing. The cause of this generally points to a camera malfunction between the camera and lens. This makes me believe that either something is restricting the lens from moving like the lens cap is tethered to the camera and tight on the lens so it can't do it's "pre" view and goes into the shut down mode. If the lens has any restriction be it the lens cap, ever ready case or anything that is restricting the lens movement remove it and try it again. I have another theory which is completely opposite to anything even suggested and that is the camera can't read the SD card so goes into shut down mode. If you remove the SD card and check to make sure the "lock" switch is in the unlock position. I'll give you a diagram for this.
The little switch needs to be pushed forward towards the gold contacts.
Diagram
