Question about Audiovox AVD300T Car DVD Player
I have the Audiovox AVD300 in my 2004 Aviator and cannot get the picture to appear on the screen. I've loaded the disc and pressed play but don't know what to do/what buttons to activate on the drop down screen
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Posted on Sep 26, 2006
micromaster
micromaster
  • 3614 Answers
SOURCE: Sound but no picture
This can be a Power supply failure- some of the filter caps could cooked dry and the yellow glue they use in this power supply turns conductive where it turns dark brown. You can unsolder the devices and feet on the heatsinks and remove them along with the stand-up driver board. Change some of the filter caps-1000u/16V, 470u/16V, 47u/50V, 10u/50V. Scrape and pick off the brown glue from all devices. Removed the fan and found the bearing was seized in it. Power supply will now run properly with the defect fan unplugged.
Posted on Feb 27, 2008
Anonymous
SOURCE: Audiovox D1812 disc loads & plays but VERY dim screen
Sounds like the backlight isn't working, could be the flourescent tube or the inverter that powers it. At least those are the likely suspects in other LCD monitors that have similar problems.
Posted on Jul 22, 2008
Anonymous
SOURCE: Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Posted on Jan 16, 2009
Anonymous
  • 814 Answers
SOURCE: Audiovox D1210 DVD won't load to play. When we put
Your DVD players may have slip out of calibration. You can try setting them back to factory specifications. To do this go to the set up menu main page. Highlight preferences and press enter.Next highlight defaults and press enter. This will reset the DVD player to the factory settings. This procedure is explained in the owners manual on page 26. If this does not solve your problem, you can try using a cleaning disc to clean the laser head and transport. This should restore the laser, and transport so that you can use it. If you are still experiencing problems with the DVD player, you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them about the problem you are having with the DVD player. I hope this information helps you with your problem.
Posted on May 30, 2009
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
My playstation is unable to read dvd movies do i need some kind of cleaner for it and what type?
dOn wOrRy all u hAv to do is
to turn on uR pS2 witthout puttin a DVD oR aNy diSc........
on mEnu screen gOto [options] by pRessing 'triangle' button.........
a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst
.....then insert the DVD movie........tURn off PS2....
press n hold the reset button till the blue light is turned on
......release the button and press it again..............
it wOuld take a little tYm foR uR DVD movie to be loAded........
be patient till the movie plays it self..............
If uR DVd still wont play then you should clean your PS2's lens Watch this video.....!!!
Oct 16, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 won't play dvds anymore but will play ps2 games just fine. What happened and can it be fixed?
This is one of the most common problem faced by old thick pS2..........but dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Sep 27, 2009 | Sony PlayStation 2 (PS2) Console
Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
Sep 11, 2009 | Audiovox D1708 Portable DVD Player
Audiovox D1210 DVD won't load to play. When we put in a DVD to play a movie, the screen displays "loading" for a while and then reads "no disc". Using a can of air (and sometimes jolting the player itself)...
Feb 18, 2009 | Audiovox D1210 Portable DVD Player with...
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Audiovox portable dvd player PVS3393
will not play dvd after loading the screen shows no disc
May 24, 2008 | Computers & Internet
Won't play blue ray discs
Your unit was built before there was Blue Ray discs. The DVD is not a Blue Ray DVD player
Apr 17, 2008 | Audiovox VD1400HT System
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Audiovox AVD300T Car DVD Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Michael Thomas
Michael Thomas
Richard Lilja
Richard Lilja
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
