Question about Polaroid FLM-2632 Television
My picture and sound both come on but it is very fuzzy and has a lot of static in the picture
Posted by jayleassiste on
louiseesberg
    New Friend:
Tv is dark when you use the scart
Posted on Jan 10, 2011
I have a Viewsonic Monitor, LED 1080p Full HD. The picture has become a little fuzzy with static like lines. How do I fix it?
The fuzziness and static could be caused by your video-card malfunction. Use your monitor on a different PC to check if this problem still continues.
Jul 06, 2011 | Computers & Internet
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
No picture but noice
Its possibly a defective vertical output IC as that can cause the picture tubes to blank out and volume will audio will remain.
Jul 06, 2008 | Hitachi 50UX57B 50" Rear Projection...
No picture
Good Day;
Try resetting the TV by unplugging from the wall A/C outlet for 3 to 5 minutes, plug back in. No fix? Your TV's LAMP needs to be replaced. Part number; UX21516, for Model 55VG825.
Good Luck, big IRISH.
Jul 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Static cling with 3 quarter inch tape
Ngotsa, Static is NOT the reason for your fuzzy audio. Old tapes tend to deteriorate because of 1.) the way they were stored (damp, humid, and extremes in temperature), or in, or near an electric field (motor, refrigerator, TV) 2.) the lubrication (which is on all tapes) has evaporated - making good tape to head contact impossible) or 3.) the oxide (the actually tape coating) had deteriorated. As far as the Black Backing, the black backing on your newer tapes IS there to prevent static, but mainly for static build-uop during high speed rewind; if it wasn''t there, you'd actually see sparks, and you'd ocassional zaps in the sound (not overall fuzziness).
Feb 06, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
RCA 25GT511 - fuzzy picture slight static sound; wiggle coax rear mount temp resolve
There might be a bad (loose) connection in the RF isolator or the tuner (both are silver boxes. Try to unplug the coax and bend the RCA tabs in so that the connection gets firmly made when reconnected. This may help. If it does not The connector may have to be replaced.
Aug 08, 2007 | RCA 32V550T 32" TV
Polaroid FLM-2632 Television Logo
56 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
