Yellow is for video; Red and White are intended for Sterno Audio. If your TV has only an yellow RCA socket, connect that Yellow socket with the pin at one end of Yellow wire, and connect the other end pin of that Yellow wire with the direct TV equipment.
Switch On both the devices [TV & DTV box], and select the TV input to AV, and see whether there is Video comes by TV. If yes, look for any AUDIO In socket at the back of the TV, Connect the other wire similarly as you did with yellow wire. For audio, only one wire connected will be enough.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
This problems,could be ur incomming broadcasting signal wire like coaxel wire like connect to tv ANT. hole input. or AV wires connection Y,R,W to ur AV input holes or those HDMI cables connections to it output HDMI ports.Take every connections of wires that are connected to the tv like input/out connections wires out of the tv.Now leave only AC power source turn on the tv and see if u get a tv LCD screen signal statics of snows only and U see no broadcasting tv incomming signal and only statics noises on the tv LCD screen only.Yes,than this problems,than it is not the tv problems,these problems it could well be caused by ur pay cables,satalites or telecomucations compannies signals broadcasting coaxel wire to the those compannies pay recieving boxes.Tries to unplug the pay broadcasting signal box u are using for about an hour.This well reset ur pay box back to the original and factory setting.Now,Ur box the paying incomming broadcasting tv channels signal pictures should return.If not talk to ur paying tv broadcasting signals commpanies for a replacement of the box u are paying for.99% of ur problems,i'm seeing u having is a broadcasting tv pictures signals that imcomming to the paying box u have a problems.This is not a tv set itself problems.
This problem has 3 possibilities, that your tv audio output is already damage or the cables that connecting to your tv and digital reciever is loosed or damage and may be your digital reciever sound pre amplifier is damage. Let's start to your tv, try to use a dvd player or cd player and connect it directly to your tv audio video input, or you can remove the connection from the digital receiver and use a small piece of wire then connect it to your tv antenna input and set your tv mode to aerial tv.If the tv produces sounds your tv is ok. To wire connection, first try to check all the cables that connecting to your tv and digital receiver specially the input, output connection,If wire is ok. Then the digital receiver has the problem try to contact service provider and ask if your digital receiver has a warranty.
Ur tv and DVD player have a S-Video connections ports holes for this wire right?Tries websites like Amazon.com,Ebay.com to buy this S-Video wire to used to do the connections for the tv and the DVD player together by this S-Video wire in tv S-Video and DVD player S-Video connections ports holes for this wire.Use the AV cable RED,WHITE same connections like ur Wii connections to get the Audio.
You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Most DVD players connect to the TV by AV (three wires), component (five wires), or HDMI (one wire) connections, none of which are tuned. That is, there are no channels on the inputs. Connect your DVD to the TV by whichever connection you choose. Then with your remote, select the input on your TV that corresponds to where you connected to on the back of the TV.
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
