Standard Horizon HX850S GPS Receiver Logo
Posted on Jan 09, 2011
Stuck on channel 69 - Standard Horizon HX850S GPS Receiver
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
464
Points
Check the LCD and see if a key symbol is displayed. If so press Hi/Lo key until Key Lock is turned off.
2answers
My element tv is stuck on channel 69
take batteries out of remote. then check for stuck or broken switches on edge of tv. they wlll send a continuous signal that blocks others from getting through.
WD40FW2610 shows please run channel auto scan then i do thes it gots up to 69 and quits
What about your Westinghouse 40" LED TV? What was the year of manufacture? Did they offer more that 69 cable channels on that model in that year? Not on UHF/VHF bands!
UHF/VHF: AIR (2-69); CABLE (1-135) • Composite/C-Video Input: NTSC
Why will my rca trflat not go past cannel 69
Hi there. Maybe your TV is not equipped for S channel reception.
Channel 73 falls into the S band; (21-69 is the normal UHF band.)
However in most cases, you must choose in wich band you scan your channels; (H, or S) I cannot imagine that this modern TV should not be equipped for S channels. Try manual channel search, where you'll probably find this possibility.
Have durabrand dct1303r tv that will not go above channel 69
you durabrand tv stay in air or tv section . so tv only showing 1 to 69 channel. you need to going to menu setup change air /tv to cable. that should be catch all channel back. good luck!
Why can't I get tv to channel 73 for dish hookup
The set returned when power removed to the AIR band which only goes up to 69.
Go into customer menu and change from AIR or ANTENNA to Cable or CATV.
We have an older model tv and can't figure out how to get the channels to above 69
Channels 2 to 69 are over the air - Antenna - channels.
Channels 2 to 125 (some duplication) are Cable channels.
There should be a way to switch your TV to Cable channels.
If it's really old there may be an Antenna/Cable toggle switch on the back of the TV.
Most newer TV's have a way to get a Menu that you can use to switch between Antenna and Cable. Check on your remote control.
If neither of those you'll probably need to buy a new TV.
2helpful
2answers
I can't go past channel 69 and I need to go up to at least channel 73
how old it the t.v. - most t.v.s are at least 181 channel compatible..hodge-podge words..in lay terms you have to have the capability on the t.v. to support X nbr of channels...also check to see if you have the menu set at cable or air...setting needs to be on cable
I have a Samsung 27" TV and need to set it on channel 73 to get a picture from my Satelite Dish. The highest channel the tv goes to is 69.
Set the TV to cable tuning mode and use that channel 73. You have it set for air now so it can only tune to channel 69.
Does tv go higher than channel 69
In 1998, UHF-69 was highest channel. you need that TV which has today's technology.
Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Top Standard Horizon GPS Experts
k24674
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
