Have an old pioneer PD-M series cd changer with box cartridge that just stopped dropping the cds just rotates through 5 cds without recognizing them to play Is it worth fixing?
The laser pickup assembly is at the end of life, remove top to expose the laser lens, use a Q-Tip and rubbing alcohol and gently clean, allow several minutes to dry, if no change! far cheaper to replace the cd changer.
incompatibility is the cause of the problem. There is nothing wrong with both your player and the computer made CD's, they are not just clicking with each other.
The Pioneer PD-M403 player is also an old model, this could cause the problem.
There is not settings whatsoever that you can use ti solve this problem.
Check to see if the laser lens is still on the laser!
If not see if its in unit and glue back on with radio/tv cement(don't super glue)! If don't work replace the laser.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams. Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position. Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses. Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts. Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position. Applicable to: Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751 also: Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
