Seems to be a problem with either the elctronics sensors, or the "brain" itself. Did you get the machine serviced by an authorised service center, or a local repair guy?
Hold down right most button for 8 - 10 seconds, then press button to program when you get your volume press button to stop repeat for next buttons, when done press stop button to get out of program mode.
HI
Without being in front of it, there are a couple of things to check.
1. There is a reset button on top of the boiler. It is a black top with a red button in the center between 2 wires.
2. The water tank needs to be emptied and then refilled.That is the first things I would check.
Machine is not heating, the lights should flash until it heats up to 1.2 bar on the top gauge. If not check the water level in the machine and check the red reset switch to see if the thermostat tripped.
It could also be that the solenoid is of the wrong specifications, and hence not getting up to pressure.. Have them check both the temp and pressure cutouts again..
