Magnifier will not turn off
HP CQ60 Magnifier SW check follow:
1. check magnifier item locate at middle down side (under the HP LOGO ) of lcd panel, you can use screw drive touch there it will be sticky. if it not sticky there---the magnifier item could be removed or lost the function, you need to open the panel to recover this function. if it works well to go next
2) the magnify receiver is located at keyboard frame top middle ( above the power switch) where is a small board in the back side. if you put any magnify stuff on the top near the power switch, laptop will go to sleep statue. if it not works, the magnifier sensor lost function, it need to repair or change the board,
hope my experience help to you!
