SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
SOURCE: turn of on it's own
I'v Toshiba and they have to replace the controler board and video board.
It is an hardware problem
SOURCE: Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
SOURCE: Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
SOURCE: Toshiba TV 35A44 Volume Issue
I had the same problem, you'll probably find that that particular button will push further into the set then the others, this is due to the a weakening of a cheesy metal guide which directs the projection off the back of the button into the corresponding microswitch. This metal guide will bend and will push against the switch.My solution, (and it ain't pretty) was to unplug the set, remove the button( I used a dremel cutting bit), locate the guide,a small metal plate with a hole in it. Bend the plate toward the front of the set then tape over the hole. I haven't had the problem since.You WILL have to use your remote for further functionality of the volume, However all of the buttons seem to be inherantly poorly designed and will weaken over time, AVOID USING THEM!
