Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a Whirlpool Cabrio top load washer and it is about 6 mos. old. During the cycle, it leaks from the bottom. The technician came out and said it was normal. I do not believe him, and I harldy think that leaking washers are acceptable byproduct of operation. He told me that it probably got out of balance, but did nothing to balance it. I am considering returning it. Any thoughts?
Posted by tsholliger on
danny Hendrickson
    President:
  • 2,468 Answers
I would surely return it and if any harassment from the dealer,call the public relations division of whirlpool and register a complaint,it could be any of 4 possibilities for a leak,but if its that new,why try to fix it yourself and void any warranty on the washer
Posted on Jan 09, 2011
Water leaking durIng cycle of machine what is a fix and a part number whirlpool cabrio
You need to give more details. It could be leaking from the water supply to the washer. A recirculating pump clamp could be loose, or a coin could have caused a small hole in the pump side wall. Or you might have a worn tub seal.
May 01, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking water from bottom of washer
Did you hear a clicking noise during the spin and drain cycle? If so, then change has gotten into the tub and discharge pump and cracked the plastic housing on the pump. had the same problem. Had to replace the pump.
Nov 25, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio top load washer leaks from underneath during the wash cycle it not the draining hoses
there is the main tub seal that could be leaking and it is between the tub and transmission.
Jan 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
372 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
