Hi
I have Sony DAV-DZ270 DVD Home Theatre System HDMI, Model. but it can't play (read) movies on my memorystick.Can only play movies that is copy on DVD recorable disc
The USB connection can only play back MP3, WMA, and AAC audio files or JPEG image files with the DAV-DZ270. The only way to play back a movie would be to capture a set of still images as JPEG and capture the audio separately. The USB device must be formated as a FAT12, FAT16 or FAT32 files system.
Yes. This is what you should do. Connect the Bluray players HDMI cable directly to your TV, then use an optical cable (usually around $20-40) to go from the Bluray player to the surround system. You will then need to enter the menu of the Bluray player and set up the Audio to be run through the Optical output instead of the HDMI. Problem solved!
I am looking to play movies through USB in Sony DAV-DZ270 without looking to buy or upgrade to any other Home theater system. Is there any firmware or software update to play movies through USB? Or can the Sony people fix my requierment?
HOLA QUE TAL COMO ESTAN ... TENGO UN PROBLEMA CON MI DVD MODELO DAV DZ270 ENCIENDE PERO ME DICE PROTECTOR Y LUEGO PUSH POWER ...Y NO SE QUE HACER .....ME IMAGINO QUE ES PROTECTOR Y NO SE COMO QUITARLO ... ALGUIEN ME PODRA AYUDAR... LE AGRADECERIA MUCHO... GRACIAS
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
Hi, You can connect external HDD to dz270... BUT you can only play audio & photos through it. It's the limitation of dz270, you can't play video through USB. dz270 cant recognize NTFS filesytem, do a FAT32 partition of 200GB or so. I bought 500GB seagate free agent ... but i couldn't use it with my dz270 to play movies :-). I could have gone for dz290 :-(
