L recently downloaded it but when l want to play l go to new game and it displays an icon written yellow and a return icon at the bottom of the screen and l cant go further
GAME OPTIONS The default options for Electronic UNO® are a Level 1, 4-player game with the sound on. If you want to change those options, this is how you do it:
1. Press the Menu button and "New Game" will flash. Press the Select button and "New Game" will stop flashing-Press again and it will go out. If you press Enter/Play with "New Game" showing you will start a new game.
2. Press the Select button then press Enter/Play. The Player 1 icon will flash.
3. Press the Select button to cycle through the number of players, represented by the 2, 3, or 4 icons, and press enter when you choose the number of players you want.
4. After the number of players is selected the, Level will begin to flash. You may change the level by using the Select button to cycle through Levels I, II or III. When you see the level you want, press the Enter/Play button.
5. Once you have selected the level, you will see the musical note icon flashing. This is the sound indicator. You may turn the sound off or on by using the Select button to make the note appear or disappear and then press the Enter/Play button. If you can see the musical note the sound is on. The Hi Score will be displayed and the player that achieved it. Press Enter/Play to start or return to your game.
6. You may start a new game, check the Hi Score or turn the sound on or off at any time by hitting the Menu button.
The right side of the screen is copped. Icannot get to the icon to cliuck to invite friends or to start to play. I noticed that the screen was getting cropped earlier. When I returned to the game The right side was cut off.Why?
There is button on your remote labeled TV/AV . Press the button to get a blank screen with AV written on the screen. If your game device is connected at the back to this AV socket ( Yellow / Red / White ) you will see the game menu display. On some of the TV remotes it might not be written TV/AV but INPUT SOURCE or just a picture of a TV screen with an arrow pointing inwards ( that LOGO is the universal symbol for INPUT )
This is the XMB its the main menu of the system. Games will be located under the Controller Icon. To play games insert a UMD, or if a game is downloaded and saved on the memory card, go through the icons under Controller icon. A disk icon will appear and show a preview screen to the game, press X to start the game.
Display Problems tend to be due to a few things. Mainly Hardware, and also software. I would check the cables from the monitor to the computer. Make sure there are no bent pins. Maybe try a different cable. Check the settings on the monitor. Maybe reset to default settings. Check the drivers for the graphic card, that they are the latest ones. Is the screen always yellow or only when playing games? Is your DirectX software ok? Maybe re-download and re-install from the Microsoft website. Does it happen on all games or just certain ones?
his umd drive may have died, depending on how old it is, you may have to send it in for repair. Also if he has downloaded any games onto the memory stick, open the bottom option under game if its not there, just re-download it from the PlayStation store.
While playing the game in another language you will see a house icon in the bottom left corner of the screen, click on it and there will be a yellow bar across the bottom of the screen (options) click on it and go to the 3rd yellow box which will be select language, you can change language when you get there. Good luck.
I had an issue with Vista and my video card. I had to go to the video cards manufacturers website and download the most recent driver for the card. Also if your game is open they won't let you exchange it for something else. I hope this works.
