Question about Emerson Televison & Video
Emerson 20" LC195EMX remote code & retail
Emerson 20" LC195EMX remote code & retail store settings? What is the code & how do I change to home settings?
Posted by mccullend on
Anonymous
    New Friend:
Hi , I just wanted to let the folks that have a emerson Lc195emx TV know that i have found no other universal remote that will work on this TV except very ironically Walmart's 5$ cheapest universal remote they have made by a company called ONN I tried LOTS expensive( LOL had to get refunds) & even my Comcast word not work , but this 5$ ONN from Walmart work like a charm there is TONS of codes for Emerson on the list , LOL i got lazy after tryin about ten and just used the auto search and in about 5 seconds it found my code and ohh my goodness i am so happy i just had to share :)
Posted on Jan 17, 2012
  • Anonymous Jan 17, 2012
    sorry did not meant to post 2 times over excited :p
Lastoni Wibowo
    President:
  • 2,246 Answers
1helpful
What is the four digit code to program an Onn MODEL ONA12AV058 Universal remote to operate an Emerson Model LC195EMX tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
How do I connect Emerson 19" model LC195EMX to direct TV
USE THE HDMI PORT WITH A HDMI CABLE FROM THE REAR OF THE DIRECT TV BOX TO HDMI PORT ON TV SET THE ON YOUR REMOTE PRESS MENU SCROLL TO THE APPROPRIATE HDMI NUMBER .OR USE VIDEO AUDIO CABLE FROM DIRECT TV BOX CONNECT TO AV CONNECTIONS ON TV SET AND DO THE SAME BY HITTING MENU SCROLL TO AV THAT SHOULD DO THE TRICK....GOOD LUCK
Codigos de control ucr 3220 para tv LC195EMX
0478,0431,0449,0461. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Codigos de directv para tv emerson LC195EMX
0035,0033,0031,0039. Try these codes.For more information http://electrohelponline.blogspot.com/Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Need remote control for LD195EMX
This is what I could find. Unless a universal remote will work. http://remotes.com/store/emerson/ld195emx.html
1helpful
How do i change screen modew without the remote on an emerson LC195EMX
Hello
It is very sorry to say that no universal remote controls are fully compactable with all the function to this set. You must have its original remote control to set all the functions. The original remote control to this set can be bought from the authorised service center for Emerson at your town. Its model number is (NH000UD). If you can get this model remote from anywhere other that service center, ie, form any local electronic sparepart selling shops, it's OK. Insist on the same model number. It is so important. Normally, remote control is an attached accessory with this set. OK.
3helpful
I have an emerson lc195emx, and can not seem to program my Vizio universal remote to sync with it. None of the codes provided work. Any help would be appreciated.
I have a 19" Emerson combination TV/DVD model LD195 EMX.
Since purchasing it I have been unable to program my Dish Network remote. Can't seem to find the proper code. Can you tell my what code or codes will work? Dish provides a list in a code book that accompanies their remote, but so far none seem to work. Please, HELP if you can.
5helpful
2answers
Need remote code for emerson LC195emx LCD TV to program my uverse remote. ATT codes don't work. Thanks
hi! i have here a couple of codes for your emerson tv. you could try them 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 hope it would work! goodluck!
3helpful
Comcast remote will not work my emerson tv
Each remote has a different code usually. So you cant get one from me, or anyone else. What you can do is call the comcast company and tell them your problem they should be able to give you a better explanation.
1helpful
2answers
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Televison & Video Logo
Top Emerson Televison & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
